heater fuse - Ford Truck Enthusiasts Forums
heater fuse
Old 10-29-2011, 03:18 PM
thomm thomm is offline
thomm is starting off with a positive reputation.
heater fuse
when i replace the 30 amp heater fuse in the dash area and turn the heater on the the fuse glows orange in seconds then blows, where do i start to fix this, maybe at the fan switch, 94 F350 box truck
Old 10-29-2011, 04:17 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I would start at the heater fan motor; the circuit breaker/fuse blowing is telling you something in that circuit is drawing more power than it should be, and I believe that fan motor is the only thing in that circuit.
Does the motor turn easily by hand? If not, this very well could be your problem....
Old 10-29-2011, 06:48 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
I'll second that!!!!
Old 10-29-2011, 09:36 PM
i can't get at it until monday but that's a good start i was thinking the switch
Old 10-31-2011, 03:19 PM
the blower motor was totally seized thanks for the suggestion on where to start looking guys
Old 10-31-2011, 04:00 PM
ctubutis's Avatar
Thanks for the update, glad you got it figured out.
1972 Highboy, turn signal fuse blows, when heater is on Taylor Anderson 1967 - 1972 F-100 & Larger F-Series Trucks 3 10-24-2016 02:20 PM
98 F150 4.6 block heater fuse yellowsnakes 1997 - 2003 F150 6 03-05-2014 10:27 PM
Water in fuel sensor. dn29626 1999 - 2003 7.3L Power Stroke Diesel 3 12-15-2011 05:48 PM
Heater fan fuse keeps blowing secakc 6.0L Power Stroke Diesel 4 01-29-2011 05:53 PM
blowing heater fuses just1me Electrical Systems/Wiring 11 06-15-2006 06:44 PM
Tags
1996, 2000, 93, blower, bronco, f150, f250, ford, fuse, fuses, heat, heater, motor, popping, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
