Torqshift Transmission Question - Ford Truck Enthusiasts Forums
Old 10-29-2011, 03:08 PM
mtullis mtullis is offline
mtullis is starting off with a positive reputation.
Question Torqshift Transmission Question
When my truck is cold the transmission has a "shutter" when your going down the road under light load in high gear/OD. It's like its locking up and unlocking the OD/torque converter?
Only does for the first few minutes and if you turn on the tow haul it goes away.
Truck is a 2006 F250 6.0L CC 4x4 60K Miles
Old 10-29-2011, 05:40 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
How's fluid level? Changed it lately? How many miles on this fluid?
Old 10-29-2011, 06:12 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
also see if the fluid smells Burnt
Old 10-29-2011, 06:44 PM
Unrealo4's Avatar
Unrealo4 Unrealo4 is offline
Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.
Everytime I hear that the problem is a shudder that goes away in tow/haul mode. It makes me lean toward injector problems. That is what mine did when the injector went out. Also my boss's 06 used to shudderonly when it was cold. Now its all the time. And he has codes for his whole passengers side injectors. Btw the shudder is harder to feel in tow/haul mode. Have your truck checked for codes IMO.
Old 10-29-2011, 08:34 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
That could also indicate a failing ficm.
Old 10-31-2011, 06:48 PM
Unrealo4's Avatar
Quote:
Your right but it passes all tests and never dips below 47.5 volts.
Old 11-01-2011, 06:34 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
I tend to think injectors too and I agree with your diagnosis of the OP's problem, but your boss's truck throwing codes for a whole bank of injectors at once makes me think something else is going on. What codes?
Old 11-01-2011, 08:58 AM
Unrealo4's Avatar
Its the contribution/balance codes for 3,5,7. I agree though I've tried changing to synthetic oil, new OEM filter and filter cap. At first his problems were only are first start after a cold soak. Now its all the time. I hope to have some time with his truck in a week or two.
Old 11-01-2011, 10:38 AM
Ewwww. The fun ones, of course. I'm wondering if he has a leaking copper washer on one of those possibly. Might want to run a bubble/balloon test before pulling them out just to rule out a leaking injector.
Old 11-23-2011, 06:08 PM
DrumboyTroy DrumboyTroy is offline
DrumboyTroy is starting off with a positive reputation.
2004 Shudder
My truck started doing the very same thing about a week ago. Sometimes the shaking is violent! It only does it in OD. It only does it under light load. It seems to go away after the truck has warmed up. If I switch to Tow-haul it stops.
Now, with that said, if it threw a code, wouldn't I have indication on my instrument panel? I have had none. Also, if it was the injector(s), wouldn't I see a reduction in RPMs when it was happening? My tack is as steady as a rock when it happens. My levels are correct. My fluid has about 4k miles on it and is nice and red. No burnt smell. Filters have also been changed. I also run the Bully Dog Triple . Have nevr had a problem. I have read lots of the same problems without bullydog in the equation. Just saying that before you jump right to the bullydog issue. I appreciated any guidance from you pros. Thanks, Troy. 157k miles on the truck. I
Old 11-23-2011, 06:20 PM
Snuggyworm's Avatar
Snuggyworm Snuggyworm is offline
Snuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to behold
i have read and heard from techs and mechanics that the bully dog might not agree wif our 6.0. no offense. jus my 2 cents.
Old 11-24-2011, 07:58 AM
Quote:
I have heard the same, but obviously turf are problems with these trucks aside from the bully dog. I want to get as much info as I can. Thanks.
1998 E Super duty RV E4OD Transmission AF_MAC Clutch, Transmission, Differential, Axle & Transfer Case 5 07-05-2014 07:45 PM
E4OD Slip Yoke nickmav70 1987 - 1996 F150 & Larger F-Series Trucks 3 07-07-2010 10:43 PM
1996 E4OD solenoid block in older E4OD transmission Hilux 1987 - 1996 F150 & Larger F-Series Trucks 8 10-12-2009 05:38 PM
E4od overdrive troubles Jimkinger 1987 - 1996 F150 & Larger F-Series Trucks 2 04-22-2009 04:26 PM
1993 Ford Explorer Transmission Question Joebuddens Explorer, Sport Trac, Mountaineer & Aviator 3 03-29-2007 10:28 AM
Tags
2003, 2009, 5th, 60k, diesel, f150, f250, fluid, ford, problems, shift, shudder, testing, torqshift, torque, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
