thank you! 1 more thing i found odd. on the alternator is the little ground stud not supposed to have anything connected to it? there is a black wire going to the positive on the alternator. is this weird? and there are 2 wires with female connections going onto he male ends.
ok now im stummped. i just put 2 new batteries in the truck. took the alternator off and had it tested, it was good. put a new regulator in and it still wont keep the batteries charged. what else could it be?
Where did you get the regulator, most of the cheap ones are crap out of the box. Get a voltmeter and see what your putting out with everything hooked up. You should have at least over 13volts 14.4 is ideal. Try running a ground wire to the alt and see if that helps, mine does have a ground. Oh and the screw that holds the regulator down SHOULD have a ground wire on it because the reg needs to be grounded, but due to the plastic inner fender it needs the wire.
Test your running voltage, just right on the battery posts is fine, you can also check voltage at the glowplug selonoid. If its at 13 volts or more you may just have poor batteries.
12.17 indicates you are not putting out anything on your alternator. Should be at least 13 volts, hopefully close to 14-14.5 volts. A cheap alternator test is to put the end of a screwdriver at the back of the alt at the center bearing. It should have a slight magnetic pull on the screw driver end.
It sounds as if your regulaotr is not working, did you put the ground wire from regulator to chassis?
