Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 10-29-2011, 10:41 AM
pells49 pells49 is offline
Garage is empty, add now
pells49 is starting off with a positive reputation.
Ignition switch
How's it goin? I've got a problem with my ignition switch in my 59 f100 which has come loose from the dash. It's hard to tell but it appears that the bezel is holding that sucker in? Is there another clip or something that may have fallen out that keeps the entire switch from spinning when i turn the key? Driving me crazy, and i can't seem to find any info on it. Thanks.
  #2 (permalink)
Old 10-29-2011, 07:23 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
You could say that the bezel holds it in but there is more to it than that. There is a large spring behind the dash that holds pressure against a spring cup that has two little ears on it which fit into the two corresponding notches in the dash behind the bezel. The spring must be compressed (by grabbing hold of the swith body and pushing towards the dash), to cause the ears on the spring cup to stick thru the dash which in turn the bezel turns into the spring cup and is held in place with two internal ears of it's own.
I trust that is as clear as mud. Someone around here probably has a pic of this, wait awhile, it will show up.
  #3 (permalink)
Old 10-29-2011, 10:09 PM
Hey thanks, I think I got it. Turns out when I reinstalled he switch, the spring cup wasnt seated into the groove on the switch, allowing it to spin in the cup.
sometimes its the little things that'll drive ya nuts! Thanks for the help.
Tags
1957, 1966, f100, ford, holds, ignition, switch, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
