E4OD Transmission Problem! - Ford Truck Enthusiasts Forums
Old 10-29-2011, 10:39 AM
rmalottwtes30's Avatar
rmalottwtes30 rmalottwtes30 is offline
rmalottwtes30 is gaining momentum as a positive member of FTE.
Went out this morning to move my truck around. Reverse seems fine, I put that sucker in Drive and take off and it feels like your holding the brake pedal down, and taking off. I hit the pedal real hard and got a bunch of black smoke but it just would barely move. I think OK brake sticking? Well I drop it down into 2nd gear and it seems to take off fine...What freaking gives? What can I look for to figure out the problem? I'm hoping the transmission isn't going out on me! This happens the day after I let someone else drive my truck.
I think I will start off by jacking it up and double checking the brakes and emergency brake cable.
Today it was sort of cold out, I dont think that has any effect on my problem. Would a clogged transmission filter cause this problem?
Old 10-29-2011, 11:02 AM
Fluid is full, fluid is still nice and red.
Got some news I didn't want to do this but I drove it down out dead end road, the truck is stuck in a high gear, it didn't shift at all on me. I think to check the Shift points and this is what I got. At idle its at 1.24 and WOT its 3.63???????HMMM Think the TPS is bad?
I cant tell what gear it is in, lets assume OD. I have no blinking OD light either. I put that sucker in 4x4 low it felt fine only because of the low gearing, but in 4x4 high I'm getting the slow take off. Like taking off in a high gear in a 5 speed or similar. What could cause it to not shift down, why is it stuck in a high gear?
Old 10-29-2011, 11:12 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is online now
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
if it takes off fine in manual 2nd,then it can in auto 1st too (D) as far as eliminating the sticking brakes i mean.
get your thinking cap on.it's time to diagnose electrical issues.
so it does move,but just barely.so lets assume for now,that the trans is trying to take off in 4th (OD) gear.
you lent your truck out.did your friend drive off road,in water/mud etc?
at any rate,start by removing the solenoid pack plug and inspecting the wires and plug itself.clean and then apply bulb grease and plug back in.
edit,
just saw post #2.
STOP doing what your doing if you want to keep your transmission.
put her in manual 2nd and drive it slow and easy back home.
Old 10-29-2011, 11:22 AM
I only took it right up the road to see if it WOULD shift. Only did it once. It is at home right now. The friend said it drove fine yesterday, he just drove it not even a mile up the road. then this morning started the problem.
I am getting voltages from the TPS and its steady reading from idle to WOT so I guess I can throw the TPS out as a problem.
Ill get under the truck and inspect all connections and grease them up. Should I back up and down the drive way again to check to see if the problem goes away or what else should I do?
Yes the truck will move, its just something with the automatic shifts. I hope it is something I can fix.
Old 10-29-2011, 11:25 AM
it is a problem you can fix.it's most likely a bad EEC relay.
Old 10-29-2011, 11:29 AM
Where is it?
Old 10-29-2011, 12:55 PM
Sorry for the crappy cell phone picture. I kept trying and trying with no luck to get a clean picture.
This is the plug that plugs into the passenger side of the transmission. I took it up over the top so I can get more slack out of it. It looks like all the wires are bare about 1 inch back coming out of this connector. Could this cause it? Can I find a new end for it, or will I have to fab things up?
Old 10-29-2011, 03:12 PM
that's most likely the issue yes.start by repairing/replacing that plug for sure.
all those wires are from the brain to all the solenoids in the trans.its imperative to have all these connections flawless.
what your posting is actually a very common occurrence.
when repairing/replacing,make sure all connections are weatherproof heat shrink connections.
Old 10-29-2011, 06:50 PM
Old 10-29-2011, 07:16 PM
yeah.she won't work too good for ya like that.
you can ease your friends mind,by telling him he's at no fault.he was just the lucky one who happened to be driving when your wires jiggled just right to finally cause the issue.
# 36445EK
Wiring harness repair kit, E4OD, 1989-94
External Wire Harness, Plugs Into Connector …. Common brands - Various
http://www.bulkpart.com/Merchant2/me...-4R100solenoid
or
http://www.trannybuilder.com/store/p...roductid=18894
here's a nice deal with heat shrink;
http://www.transmissionpartsusa.com/...-00026389a.htm
Old 10-30-2011, 09:20 AM
You think any local parts stores would carry something like this?
Old 10-30-2011, 05:08 PM
Well all that work for nuttin..Someone keeps telling me about a relay that could be bad, BUT WHERE?
Old 10-30-2011, 07:51 PM
yeah,but where? good question.this i don't know.
im sure david85 has posted their locations a time or two,if you advance search "relay" with username "david85" you'll probably find it.
i know there's relay's in the under hood fuse panel (which is where id guess they are) but i don't have a diagram for this panel.
repairing/replacing that plug wasn't for nothing though.you couldn't leave it like that regardless.your doing it right.fix the obvious (and free stuff) first.
besides,those wires shorting out,could have been what took out your EEC relay (if that turns out to be bad) in the first place.
did you find one of those replacement plugs locally?
Old 10-31-2011, 05:49 PM
I found out where the relay was, by the relay box well behing it, there is two relays seperated and one is the ABS and one is the ECC relay. Swapped the two around beings my ABS is bypassed. Still have the same results. Would a bad or misaligned mlps cause this?
Old 10-31-2011, 06:11 PM
here we go:
Bulletin: #125
so test for voltage at the solenoid plug.where your wires were bare.it says pin #1.
also shows the EEC relay location.
(and '92 owners should note the diode location.)
i don't know as if a bad MLPS would cause an OD start symptom.usually she'll pop into neutral on ya when those fail.
i hope you didn't fry your solenoid pack due to those bare wires.
making sure you have voltage at pin #1 is where id test next.
here is info on testing the MLPS.
it does say they can cause a wrong gear start.so i guess this includes 4th too then right lol.
what the heck.it can't hurt to test that next:
http://www.transonline.com/transDige...ers/index.html
fyi,
should that test bad,they now make a better weatherproof plug on replacements.so be sure to get the updated version with the plug adapter.
of course while testing,be sure to clean and inspect this plug too.it doesn't want to look like your solenoid pack plug did either.
keep at it.you'll find the problem.doing good.
Why do my brakes need pumping to build pressure? Ranger1979 Brakes, Steering, Suspension, Tires, & Wheels 16 02-07-2017 11:03 AM
1979 F600 Brake hydraulic pressure not releasing norust 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-17-2016 09:20 PM
Clutch\brake pedal cliffordingles 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 07-14-2016 11:29 PM
why do my brakes need pumping to build pressure? help Ranger1979 1973 - 1979 F-100 & Larger F-Series Trucks 28 07-03-2016 10:38 PM
No brake pressure... Bad Brake Booster? stephenok711 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-02-2012 05:59 PM
Tags
1994, 96, e40d, e4od, f350, ford, high, mileage, numbers, problem, problems, sensor, slack, temperature, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
