E4OD Transmission Problem!
I figured out how to test for codes using a digital multimeter. Now I just got to figure out how to read the codes.
I use a wire from the ground to the Self test input then use a multi meter with it set to continuity and go from the positive side of the battery to the self test output.
I put the go pedal to the floor then turn the key on, then I am getting a bunch of rapid flashes of the meter and pauses.
on
ok.let's see if i get these right.don't take these codes to the bank though ok.iv never read them before with a meter.so bare with me.....
11 = System checks OK.
56 = Transmission Oil Temperature sensor too high
13 = (O) ISC did not respond properly (extends to touch throttle then retracts for KOEO)
(R) Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high)
(M) ISC sticking, open ITS circuit or TP sticking
67 = Park/Neutral circuit fault
Transmission Manual Lever Position (MLP) sensor circuit
(M) Intermittent Park Neutral Position (PNP) sensor fault
35 = EVP - (R) Engine RPM's too low to test EGR system
EVR - (O, R, M) EVP sensor signal is/was high
PFE - (O, R, M) PFE sensor signal is/was high
holy crap man lol.
id be testing the MLPS.
holy crap man lol.
It's not the MLPS. That may be bad, and it can cause problems, but it cannot make the trans start in overdrive, which is what you have.
The ONLY way that can happen is when you don't have a good connection to the solenoid body. You may have power at the connector, but you probably don't have power all the way to the solenoids or the ground wires to the solenoids are bad.
on
drop the pan to gain access.
help removing e4od solenoid pack - FSB Forums
this info will be handy for you now:
Transmission Application E4OD : Solenoid Resistance (Ohms)
Shift Solenoid 1 : 20-30
Shift Solenoid 2 : 20-30
Torque Converter Solenoid : 20-30
Coast Clutch Solenoid : 20-30
Electronic Pressure Control : 4.0-6.5
should you diagnose the solenoid pack as bad,here is a place to buy replacements if you want new;
4L60E 700R4 4L80E 4R100 E4OD 2004R C6 TH350 TH400 Transmission Parts: New E4OD Transmission Solenoid Pack 1989-1994
"You may have power at the connector, but you probably don't have power all the way to the solenoids or the ground wires to the solenoids are bad. "
notice Mark is leaning more towards the wiring to them (id agree too after looking at that plug.who knows how long those wires where left exposed and how deep the corrosion goes) rather than the solenoid(s) being faulty.
so,should you decide the wires are good,be sure to measure the resistance to them.......how i don't know though lol.the thing must come apart,or you do so at the pins perhaps.i was about to do this to mine,but didn't have to go so deep luckily.
#30
