Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 10-29-2011, 09:52 AM
Jrakar Jrakar is offline
Garage is empty, add now
Jrakar is starting off with a positive reputation.
Clicks but won't start
Got in my 2007 Expedition and turned the key and all I get is a click sounds like a machine gun going off. Got battery...lights and radio works. Any suggestions before I call the shop?
  #2 (permalink)
Old 10-29-2011, 10:09 AM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
I say it's the battery. Just because your lights work and radio works doesnt mean the battery has enough juice to start the vehicle. Can you put a volt meter on the battery and check it while someone cranks it?
Matt
  #3 (permalink)
Old 10-29-2011, 10:17 AM
glruff's Avatar
glruff glruff is online now
2005 Ford Ranger
glruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputation
Yup I would say the battery also.
Check the terminals and make sure they are not corroded. If they are, clean them and see if you can get the vehicle started.
__________________
George, FTE Chapters Moderator - FTE GUIDELINES
05 F250 6.0 FX4, Innovative Diesel Tunes/10 Expedition EL LTD/12 Explorer LTD EB/13 Platinum F150 EB
  #4 (permalink)
Old 10-29-2011, 12:36 PM
Jumped it and it started right up. Took it to have the battery tested and they told me that the battery was 100%. The guy at Auto Zone asked me if I checked the starter. He told me that ford is known for the connections going bad on the starter? Any truth to this?
  #5 (permalink)
Old 10-29-2011, 01:49 PM
Johnny Law Johnny Law is offline
Johnny Law is starting off with a positive reputation.
If it jumped just fine, then it most likely is not an issue with corrosion at the starter. Possibly corrosion at the battery terminals as it won't charge as well as it should.
  #6 (permalink)
Old 10-31-2011, 06:27 AM
Cleaned up the terminals on the battery and put a battery charger on it to make sure it was fully charged last night. Got up this morning and battery had 12.6 volts. Again clicking no start. Put the charger on for about 5 min and it started right up. I thinking of getting the battery tested again. I took a look at the starter cables and they look good and tight. Any further ideas?
  #7 (permalink)
Old 10-31-2011, 11:20 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
You have to get battery load tested
Even then, it can test good, but will still be bad. I suggest a 800CCA or bigger battery.
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #8 (permalink)
Old 11-01-2011, 02:56 PM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
Try honking the horn next time. The horn puts a pretty good load on the battery. If it sound weak then it is your battery.
Next would be to make sure you are all the way in Park.
__________________
See ya,
Eric
Tags
2003, 2004, 64, ans, charge, clicking, clicks, diesel, expedition, f250, ford, full, makes, navigator, ranger, start, starting, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
