Modular V10 (6.8l)
View Poll Results: Replacement studs or bolts?
Studs (like Ford supplied originally)
66.67%
Bolts Ilike the did them back in the day)
33.33%
Voters: 9. You may not vote on this poll
Exhaust manifold - replacement bolts or studs
Old 10-28-2011, 09:45 PM
neilc88's Avatar
neilc88
neilc88 is offline
Hi guys,
After the X got loud recently, I found I have 4 broken exhaust manifold studs.
My Excursion is parked outside year around, and we have had record rain here this year. Is is always damp outside.
I want to go with stainless steel replacements.
Now the question, bolts or studs??
Does one have an advantage over the other? Which would be easier for reinstallation?
Whoops on the "bolts" in the poll. I ment to say, "like they did them back in the day."
Old 10-28-2011, 10:08 PM
ggazz50's Avatar
ggazz50
ggazz50 is offline
Mine just started leaking and has two nuts missing on each side (pass/drivers). I’m having the same dilemma, SS studs or SS bolts? I’m watching this poll closely!
Old 10-28-2011, 10:43 PM
Ricohman's Avatar
Ricohman
Ricohman is offline
I replaced the broken bolts with Ford studs. No problems and many miles since.
Old 11-02-2011, 08:53 PM
RWG78's Avatar
RWG78
RWG78 is offline
I used the bolts from a GM 6.0 V8 (I work for GM and drive Fords, go figure). I used the ebay headers and three years later, no problems.
Old 11-02-2011, 11:21 PM
57meteor's Avatar
57meteor
57meteor is offline
studs are used in aluminum because of the softer threads.once the studs are in,you use the nut to remove the part.so you will not work/damage the aluminum threads
Old 11-03-2011, 08:12 AM
ggazz50's Avatar
ggazz50
ggazz50 is offline
I'm going with the stainless studs and thinking of using anti-seize on them. Should It be used on the end that goes into the head or just on the threads that hold the nuts?
Old 11-03-2011, 04:53 PM
57meteor's Avatar
57meteor
57meteor is offline
put anti seize on both ends,especially on stainless
ryno_rx8
Modular V10 (6.8l)
10-26-2012 06:43 PM
Si11ynood1er
06-29-2012 04:32 AM
greeneon_01
08-03-2010 10:24 AM
AUBronco40
1978 - 1996 Big Bronco
12-05-2003 01:12 PM
roy 61
11-06-2003 03:48 AM
Quick Reply: Exhaust manifold - replacement bolts or studs
