Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V10 (6.8l)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
View Poll Results: Replacement studs or bolts?
Studs (like Ford supplied originally) 6 66.67%
Bolts Ilike the did them back in the day) 3 33.33%
Voters: 9. You may not vote on this poll
  #1 (permalink)
Old 10-28-2011, 09:45 PM
neilc88's Avatar
neilc88 neilc88 is offline
Garage is empty, add now
neilc88 is starting off with a positive reputation.
Exhaust manifold - replacement bolts or studs
Hi guys,
After the X got loud recently, I found I have 4 broken exhaust manifold studs.
My Excursion is parked outside year around, and we have had record rain here this year. Is is always damp outside.
I want to go with stainless steel replacements.
Now the question, bolts or studs??
Does one have an advantage over the other? Which would be easier for reinstallation?
Whoops on the "bolts" in the poll. I ment to say, "like they did them back in the day."
__________________
2002 X, 4x4, Limited Ultimate, 285 Revos, Bilstein shocks, Edge mini-spring kit, F-350 4" rear blocks, S.S. speed grill, Lund trim color deflector, Hellwig rear sway bar, tinted windows, Sure-Drain.
  #2 (permalink)
Old 10-28-2011, 10:08 PM
ggazz50's Avatar
ggazz50 ggazz50 is offline
ggazz50 is starting off with a positive reputation.
Mine just started leaking and has two nuts missing on each side (pass/drivers). I’m having the same dilemma, SS studs or SS bolts? I’m watching this poll closely!
  #3 (permalink)
Old 10-28-2011, 10:43 PM
Ricohman's Avatar
Ricohman Ricohman is offline
Ricohman is starting off with a positive reputation.
I replaced the broken bolts with Ford studs. No problems and many miles since.
__________________
2010 F350 4x4 6.8 XLT XTR CC
  #4 (permalink)
Old 11-02-2011, 08:53 PM
RWG78's Avatar
RWG78 RWG78 is offline
2009 Ford F-350
RWG78 is starting off with a positive reputation.
I used the bolts from a GM 6.0 V8 (I work for GM and drive Fords, go figure). I used the ebay headers and three years later, no problems.
  #5 (permalink)
Old 11-02-2011, 11:21 PM
57meteor 57meteor is offline
57meteor is starting off with a positive reputation.
studs are used in aluminum because of the softer threads.once the studs are in,you use the nut to remove the part.so you will not work/damage the aluminum threads
  #6 (permalink)
Old 11-03-2011, 08:12 AM
ggazz50's Avatar
Quote:
I'm going with the stainless studs and thinking of using anti-seize on them. Should It be used on the end that goes into the head or just on the threads that hold the nuts?
  #7 (permalink)
Old 11-03-2011, 04:53 PM
put anti seize on both ends,especially on stainless
Tags
69, 73, bolts, exhaust, exhaustbolts, expedition, exsaust, ford, manifold, manifolds, replacement, stainless, steel, studs, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
