I know Chevrolet recommends not to tow over 70mph with the O/D off.....is Ford the same way?
I am towing a 3000lb trialer to Texas (1200 miles) and am not planning on running much over 70 and was just wondering.
Thanks
You'll get a lot of different opinions on this, but here's mine:
It's fine to tow with OD as long as the transmission is not hunting. On level ground, at highway speeds, leaving OD on is fine and does not damage the truck.
I plan to leave the O/D off most of the time anyway....was wondering more about driving over 70 wit it off. Trucks turns approx 2800 at 70 with the O/D off.
Thanks
You won't hurt anything running with OD off. You'll use more fuel, though. If the trailer is only 3000 lb. it won't hurt a thing to tow with OD on as long as it's not hunting gears. I use OD towing my 7000 enclosed car trailer as long as the tranny isn't hunting gears and the engine isn't lugging. I do watch the trans temp also.
