6" lift questions
#77
Double check to make sure the shoo is giving you the same stuff rough country is. Sometimes RC gives you a free steering stabilizer the shop may try to charge extra for that. Also get the kit and so the rear yourself. Save some labor money.
#78
The only hard part about installing a lift kit is grinding the rivets out to bolt all the new brackets in. Otherwise, it is pretty much just a matter of taking it apart, and putting it all back together.
x2 on doing the rear yourself, for sure. My Rough Country kit came with the wrong u-bolts for the rear though. They were the same size as what my truck already had, and when I called they refused to make it right with me. Instead they told me I needed to take my overload springs out, which wasn't going to happen, so I had to have custom u-bolts made (ran about $110).
#79
OzFTrucker
02-12-2005 06:41 AM
