Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 10-28-2011, 01:44 PM
mkrog mkrog is offline
Garage is empty, add now
mkrog is starting off with a positive reputation.
Unhappy window adj.
Got a 57 F100 and the drivers door window ***** and binds when I try to roll it up or down, new glass run.Whats the fix?I have tried to adj. it .Do I need a new division bar?
  #2 (permalink)
Old 10-28-2011, 07:52 PM
rcjccobra rcjccobra is offline
rcjccobra is starting off with a positive reputation.
That's called "racking" and it's typically caused from the glass being cut too small.
  #3 (permalink)
Old 10-28-2011, 08:11 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Out of everything I did to redo my '60, adjusting the windows were the hardest. Still have one that isn't perfect and I used the original glass.
Be patient and keep at it.
  #4 (permalink)
Old 10-28-2011, 11:13 PM
Quote:
It's the original glass.
  #5 (permalink)
Old 10-29-2011, 07:07 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
It has been a few years since I did mine, but it sound like the division bar is either out of adjustment, moving or maybe needs replaced. The bar on the outside of the door could also be moving. Dennis Carpenter's catalog that you can download has a step by step procedure on how to replace the window system, it may be helpful. If the glass is original, one would think that it is sized correctly. Good luck.
__________________
Walston
http://bigjohnstractor.com/
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
