A/C TEMP PROBLEM, PLEASE HELP!
Old 10-27-2011, 08:52 PM
Crownline04's Avatar
Crownline04
Crownline04 is offline
2004 F150 with Auto Climate. If I put the setting on 60 I get Ice cold A/C, If I change it one click to 65 I get VERY hot heat. There is no adjustabilty.
I just replaced the actuator with the updated one and that did not fix my issue? Any suggestions besides dealer?
Thanks
Old 10-27-2011, 10:45 PM
Crownline04
23 views and no response? Come on guys I need some help with this...
Old 10-28-2011, 12:37 PM
tooldad's Avatar
tooldad
tooldad is offline
First thought too was the actuator based on my personal experience. Second thought would be an issue with the cotrol unit. There is a combination of button pushes that (on control) that will show any related error codes, but I do not know how to do. Sorry. I just watched a tech do it once. So, short of trying to replace the control unit, I am at a loss to help. Good luck.
Old 10-28-2011, 05:12 PM
aquaman's Avatar
aquaman
aquaman is offline
Maybe a bad connector connection behind the ETAC?
My problem is I get heat even with the temperature set to minimum. Stupid blend door must not be closing all the way.
terryingeorgia
2004 - 2008 F150
19
05-26-2014 07:59 PM
bigwiege
2004 - 2008 F150
01-31-2011 07:07 PM
mohle
1999 to 2016 Super Duty
11-11-2010 08:47 PM
cdestuck
2004 - 2008 F150
10-20-2009 08:52 PM
hank_48
12-26-2002 12:40 PM
Quick Reply: A/C TEMP PROBLEM, PLEASE HELP!
