To KingPin or not to KingPin
76 F150 Longbed 390/C6/9in
I've been replacing everything up front, complete suspension, bushings along with removing items for paint and such as well. Making it all look nice and pretty.
Here's the delima:
My current kingpins are tight, no wobble-loosness-shiftyness, grease nipple still functions and everything seems right with them. I've heard a set of king pins will last the life of the truck......sooooo.....to change them (just because everything else is new) or not to? (since it aint broke don't fix it)
I'm torn. Getting the kingpins changed will delay the refurb/rebuild another two weeks or so and the weather may not hold out long enough to get everything put back together, to get the truck onto the trailer, to get it to the engine shop for it's new heart transplant.....
Not that's it's too hard to pull the rotor hubs and pull the I beams in the future if I needed to but I just can't make up my mind either way.
So do KingPins actually last the life of the truck?? (maybe another 30 yrs?)(60+years total?)
Here's the delima:
.. great question. I think that's Shakespeare, right?
First, kudos for detailing the entire front end because that takes alot of patience. Not only will painting the parts protect them, but to me it's very rewarding not having to work on a grungy truck (after it is assembled).
Kingpins can last a lifetime IF they are diligently maintained . With that said, you're probably not the original owner so their actual condition is unknown regardless if they feel as if they have no play. However, the subsequent work needs to be done and a matter of priority. I'd pass on the kingpins for now just to stay on schedule.
The detailing is actuall ignorance and ADHD. I figured I touch up a few things while the engine is being built....then the ADHD kicked in. Though simple to actually do and easy to tear apart, it's the little things like replacing every bolt and washer and brake line or spring cup that's startin' to kill me right now. It's one of the reasons I'm behind now....
As far as knowing the origional owner...yep I do. Rode in the truck many times as a teenager. One of the reasons I kinda feel "OK" leaving the origionals in. If the grease nipples weren't working, I'd be more sketcy but since I can squeeze fresh grease in, I think I may let it slide for now unless someone else convinces me otherwise....
Guys - that's OCD - which I have as well. My problem is the ADD kicks in for me and I go work on a completely different project. There is a reason I have 3-4 builds going on at once. That reason is "car ADD". The Reason they are all never done is I'm **** about doing things right = OCD.
I just tore into the wiring on my alfa last night. It will take a lot longer to get the thing working redoing a bunch of it the way I am, but I want the thing RIGHT!
Oh - and as far as the kingpins go - like all have said - leave um!
82_F100_300Six
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
08-12-2019 01:10 PM
kramttocs
03-07-2018 08:01 AM
Splash440
09-17-2017 08:56 AM
jwallis
09-06-2015 05:26 AM
