Eaton Truetrac Gear Oil - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 10-27-2011, 06:44 PM
xupkid2 xupkid2 is offline
xupkid2 is starting off with a positive reputation.
I just installed a Eaton Truetrac limited slip in my 2008 F250 and am wondering about what kind of gear oil to use. I normally use the Amsoil Severe Gear 75W/140 but read somewhere on the board that you shouldn't use synthetic with the Truetrac. Conversely, I read in the owners manual that the Truetrac differential is designed to operate in those lubricants recommended by the vehicle/axle manufacturer for conventional differentials.
Does anyone have any insight into what kind of gear oil I need to use. I don't want to have issues nor take any risks ruining the new LSD.
Thanks
Brian
Old 10-27-2011, 07:35 PM
golfmedik's Avatar
golfmedik golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
I used Royal Purple in my Silverado when I installed my Truetrac. I used the gear weight recommended for the truck as found in the owner's manual. Can't remember right of hand what weight it was though. You might also find that it says not to use friction modifiers with it as well since it doesn't have clutches to wear out.
Old 10-29-2011, 07:22 PM
Anomic Anomic is offline
Anomic is starting off with a positive reputation.
Kid you put it in the front or rear axle? How do you like it?
Old 10-29-2011, 07:58 PM
I put it in the rear and used Amsoil Severe Duty. So far so good but havent driven it much.
Old 10-30-2011, 06:38 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
User Sawtooth has the tru trac in his for a long time. Look him up and shoot him a vistor message. (you can't pm since you are new here).
TrueTrac Diff Oil Question DSN46 Excursion - King of SUVs 10 07-07-2016 04:46 PM
Best Gear Lube For Eaton Truetrac CTC01 1987 - 1996 F150 & Larger F-Series Trucks 2 11-19-2014 11:44 AM
eaton truetrac adjustment? Gerby Dutchy 2009 - 2014 F150 10 11-14-2014 01:54 PM
Eaton Posi or Detroit Truetrac? lasitter 1987 - 1996 F150 & Larger F-Series Trucks 6 06-13-2014 12:32 PM
What gear oil for true-trac 96grimreaper Excursion - King of SUVs 7 08-25-2012 10:36 PM
Tags
08, 2008, eaton, f350, ford, gear, lube, oil, synthetic, trac, trake, true, truetrac, ture, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
