Plugs, COP's, Boots
Plugs, COP's, Boots
So the local shop quoted me like $380 to change out the plugs in my 2002 v8. They quoted me bosch plats for like $25 each, and the rest is labor.
So I'm kind of on a budget so I've been looking around. Going to Ford's website, the DG491 (same thing as a 508??) cops for my truck are $75 each, and the plugs SP479 are like $7 each.
Ive been watching ebay, and the COPS seem to average $49 or higher. I saw someone post on here they just got a whole set for the mid $300s.
So I found this today:
Genuine New Motorcraft Ignition Coil DG508 DG491 FD503
$39 each for the coil and boot (unless they remove them from the box).
Anyone ever here of this company? Is this a good price, or should I keep shopping? My truck is still having the stumbling issue and Id like to replace the plugs/cops/boots all at once and be done with it.
Thoughts?
Oh, and part 2: Fords shows the SP479 as my plugs, and dg491 as my cops. Should I stick with these, or is there a better model?
Also, Ive seen used cops online with like 5k miles on them. Are these good enough to go for?
Thanks for the input!
Thoughts?
or how about these?
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
The actual auction says "Motorcraft" in the brand up top, so I messaged the seller. He confirmed that these are -NOT- motorcraft, but insists that they are made exceeding OEM requirements and have a lifetime warranty.
Thoughts?
Thoughts?
Almost everything I read says to stay with Motorcraft parts for cops and plugs on these motors. Some have had luck with the "ebay" cops but others have not.
As for the boots/springs, I don't think the brand of those are as critical. I ended up using a set of Denso boots from Rock Auto. Definitely want to change the boots though while you're in there!
Was at dealership today. Parts guy that I have used a lot said you could not buy the boots separate. He said you have to buy the coil too? I get employee price and they are 44$ and some change each for the coil and boot. I don't need coils and i dont want to spend 450! Can u get boots from napa? Or is my parts guy wrong? I like staying w Motorcraft
I know for a fact autozone sells just the boots. I have only used motorcraft plugs on any of my fords. Autozone sells the plugs as well. There is a few good write ups on here if you want to tackle the job yourself.
I have used Ebay COP's before, they are hit or miss. After 3 bad ones in one batch I threw them away and put my old ones back on, they were better than the new ones. Unless you have a misfire then change that one. They really aren't a "maintainence item"
sniknah
1997 - 2003 F150
05-18-2011 06:23 PM
fatherdano
03-04-2011 10:59 PM
