Plugs, COP's, Boots - Ford Truck Enthusiasts Forums
Plugs, COP's, Boots
Old 10-27-2011, 02:06 PM
Codelizard Codelizard is offline
Codelizard is gaining momentum as a positive member of FTE.Codelizard is gaining momentum as a positive member of FTE.
Plugs, COP's, Boots
So the local shop quoted me like $380 to change out the plugs in my 2002 v8. They quoted me bosch plats for like $25 each, and the rest is labor.
So I'm kind of on a budget so I've been looking around. Going to Ford's website, the DG491 (same thing as a 508??) cops for my truck are $75 each, and the plugs SP479 are like $7 each.
Ive been watching ebay, and the COPS seem to average $49 or higher. I saw someone post on here they just got a whole set for the mid $300s.
So I found this today:
Genuine New Motorcraft Ignition Coil DG508 DG491 FD503
$39 each for the coil and boot (unless they remove them from the box).
Anyone ever here of this company? Is this a good price, or should I keep shopping? My truck is still having the stumbling issue and Id like to replace the plugs/cops/boots all at once and be done with it.
Thoughts?
Oh, and part 2: Fords shows the SP479 as my plugs, and dg491 as my cops. Should I stick with these, or is there a better model?
Also, Ive seen used cops online with like 5k miles on them. Are these good enough to go for?
Thanks for the input!
Old 10-27-2011, 04:37 PM
or how about these?
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
The actual auction says "Motorcraft" in the brand up top, so I messaged the seller. He confirmed that these are -NOT- motorcraft, but insists that they are made exceeding OEM requirements and have a lifetime warranty.
Thoughts?
Old 10-27-2011, 05:38 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
Almost everything I read says to stay with Motorcraft parts for cops and plugs on these motors. Some have had luck with the "ebay" cops but others have not.
As for the boots/springs, I don't think the brand of those are as critical. I ended up using a set of Denso boots from Rock Auto. Definitely want to change the boots though while you're in there!
Old 10-27-2011, 11:30 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Yikes, my plugs cost about $2 each and my boots were about the same, and I put them in myself (easy). I would never replace a cop that wasn't bad, they don't automatically go bad.
Old 09-14-2012, 11:52 PM
TX03EX's Avatar
TX03EX TX03EX is offline
TX03EX is starting off with a positive reputation.
Was at dealership today. Parts guy that I have used a lot said you could not buy the boots separate. He said you have to buy the coil too? I get employee price and they are 44$ and some change each for the coil and boot. I don't need coils and i dont want to spend 450! Can u get boots from napa? Or is my parts guy wrong? I like staying w Motorcraft
Old 09-15-2012, 12:29 AM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Parts guy is wrong. Check another store.
Old 09-15-2012, 01:41 AM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
I know for a fact autozone sells just the boots. I have only used motorcraft plugs on any of my fords. Autozone sells the plugs as well. There is a few good write ups on here if you want to tackle the job yourself.
I have used Ebay COP's before, they are hit or miss. After 3 bad ones in one batch I threw them away and put my old ones back on, they were better than the new ones. Unless you have a misfire then change that one. They really aren't a "maintainence item"
Old 09-15-2012, 10:07 AM
TX03EX's Avatar
he said it looks like you can get them seperate (Motorcraft from dealer) then when you actually go to pull the part number it shows them together only.
Old 09-15-2012, 07:43 PM
I bought Denso brand boots/springs from Rock Auto. Part number 671-8110 for my 5.4L...
Do yourself a favor and steer clear of China coils RL7 1997 - 2003 F150 17 02-01-2017 01:08 PM
Good deal on coils and boots or too risky?? jdm5630 2007 - 2014 Expedition & Navigator 9 03-29-2013 09:22 AM
Ignition coil, DG508 or DG511, which one? Pro DIY 1997-2006 Expedition & Navigator 3 07-26-2011 07:16 AM
Found COP for $13.99!!! coldairintake 1997 - 2003 F150 2 03-05-2006 01:21 AM
Another COP Question 1997 5.4 alan911sc 1997-2006 Expedition & Navigator 0 05-11-2005 12:54 PM
Tags
01, 2000, 2005, boot, boots, cop, excursion, f150, ford, forum, plugs, replacement, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
