replacing door hinges - Ford Truck Enthusiasts Forums
Old 10-27-2011, 01:32 PM
Kalve's Avatar
Kalve Kalve is offline
Kalve is starting off with a positive reputation.
Hey guys got a 74 F250 crew an was told I need new driver door hinges. Is there any way to fix the old hinges like replace a pin or bolt or something? An were is a good place to buy some hinges for these trucks?
Old 10-27-2011, 01:52 PM
whess450 whess450 is offline
whess450 is starting off with a positive reputation.
Jeff's Bronco grave yard sells hinge pin repair kits $9 per hinge. Not sure how well they work though. They also sell complete hinges for $50 per hinge I have personally never bought ether so I couln't comment on the quality of them
Old 10-27-2011, 01:56 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
As long as the bushing and pins are all thats worn, a pin and bushing kit will fix it right up.... Now if it has worn to the point of getting into the hinge itself then it would be wise to replace the entire hinge.
Old 10-27-2011, 08:59 PM
Kalve's Avatar
the guy who did the body work said the hinge needed replaced. He said the whole hinge needed replaced but I would say just the pin. He said when he went to realign the door he could not get it to line up right due to the hinge being bad.
Door Hinge Replacement on 1989 F150? Subzero68 1987 - 1996 F150 & Larger F-Series Trucks 3 08-21-2016 07:43 PM
1956 Door Pillar Hinge Fix? 1LIFE 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-10-2015 09:09 PM
51-52 F1 Door Hinges PhattRabit 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 09-14-2014 08:13 AM
door hinges mont974x4 1987 - 1996 F150 & Larger F-Series Trucks 3 08-29-2014 03:51 PM
1952 door hinges jdpolecat 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-13-2014 11:11 AM
Tags
1960, 1979, 1996, 1997fordf250doorhinge, body, door, f100, f250, ford, hinge, hinges, replace, replacing, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
