Parking brake cable.
if you already hooked up the springs that hold the shoes in place then you have to undo the one that has the park brae lever on it.
i find that grabbing the cable and wedging a pair of needle nose pliers in between the spring and the **** on the end of the cable will allow you to be able to pull the cable out of the spring a bit and grab the cable with the needle nose to give a big enough gap to slide over the bracket....
not sure if hat helped of not but good luck
I finally got it...
got it on twice, actually. Once the wrong way, and once the correct way. And what did I learn from this experience? I learned to not unhook the thing unless absolutely necessary.
I used a screwdriver to separate the spring from the end, then twisted the screwdriver to give enough space to slip it in the slot. What fun!
nickmont222
08-24-2004 07:43 PM
