Brake pedal goes to floor only when engine running - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-21-2014, 01:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
Old 10-27-2011, 10:44 AM
Fords412 Fords412 is offline
Fords412 is starting off with a positive reputation.
Truck is 1992 E350 cube dual wheel cab and chassis
Initial problem - Front brake lines rusted out, lost pressure, MC bled dry.
After replacing all front brake lines and bleeding front and rears, I got good solid
pedal with engine off, I mean I can push long and hard and it stays firm.
When I start engine, the pedal slowly goes to the floor with almost no resistance
and you hear a woosh from the booster until it gets to a few inches from the floor
and the pedal firms up and the brakes operate (stopping power).
So I replaced the master cylinder with a NAPA part and bench bled it for a good 20 strokes until only fluid was recirculating.
Installed MC and then bled brakes again (full quart) until no air came from bleeders.
I still have the same problem.
The pedal is high and firm and stays firm when I stand on it with engine off.
Start the engine and the pedal sinks nearly to the floor before it works.
Old 10-27-2011, 10:49 AM
PS this is a 5.8L with conventional booster, not a diesel.
Old 10-27-2011, 12:40 PM
Wow. No one has any advice?
Old 10-27-2011, 02:08 PM
maverick22's Avatar
maverick22 maverick22 is offline
maverick22 has a good reputation on FTE.maverick22 has a good reputation on FTE.maverick22 has a good reputation on FTE.
Sorry, I can't help you much, but I'm pretty sure you have to bleed the brakes w/ the engine running. You might try posting this down in the 87-96 forum, might have better luck down there. 1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Old 10-27-2011, 03:36 PM
Thanks, I'll try it with the engine running. The problem is it won't build up a pedal no
matter how much you pump the brakes with the engine running. It just keeps making
wooshing air sound and goes down to about 2" off the floor. I know that sounds like a
master cylinder but it is new and bench bled and it has a good pedal when the engine
isn't running or the booster isn't working. Is it possible the atmospheric check valve is
bad in the booster causing an over boost that is pushing fluid past the master cylinder
seals? Just another wild guess. This one has me stumped.
Old 10-27-2011, 07:37 PM
99f350sd 99f350sd is online now
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
Brake light off? You make have to make sure the spool is centered in the brake valve..
If thats not it do you have another leak? Look around.
Dick
Old 10-27-2011, 07:55 PM
Dick
No brake light. No abs light. No fluid leaks.
I'm not sure what you mean by the spool?
Old 10-27-2011, 08:41 PM
In most brake systems there is a valve a shuttle valve gizmo that moves to one side or the other when you have a front or rear brake circut failure.. When the brakes are working correctly the spool is centered when you lose one side the spool gets thrown off center..Don't know if you have one on your vehicle or not. Follow the brake lines. Front and rear will have to go to it..After you fix the brakes sometimes a sharp rap on the brake pedal will center it..
If not you have a leak or air..Air compresses more with engine running.
Were you able to loosen the bleeders. Sometimes calipers get air trapped in them..Do the pump it up hold down bleed method? Gets air out best. Check calipers? Pads? Hoses..?
Dick
Old 10-28-2011, 07:10 AM
Sand_Man's Avatar
Sand_Man Sand_Man is offline
Sand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud of
If I had to guess, I'd say there;s still air somewhere. Please don't get offended if this seems too basic, but brake bleeding takes a ton of patience sometimes. First, make very sure all the bleeders are at the top of the calipers. Sometimes it's easy to install the wrong caliper on the wrong side and wind up with the bleeder at the bottom rather than the top. Only fluid will come out because all the air is trapped in the caliper.
Second, as I found out when I restored my '68 Mustang, replacing all the brake lines means everything is dry and all those kinks to get over stuff are great pockets for air to hide. I start with the wheel farthest from the master cylinder (passenger's side rear) and bleed it until you think you have all the air out. Next move to the driver's side rear and work on it, then move back to the other rear. Once you think you have the whole rear done, move on to the front, doing the passenger side front first, then the driver's side front. Then start over, and see if you find air somewhere. Keep an eye on the master cylinder's fluid level and keep looking for leaks. If it's not leaking then it HAS to be air somewhere. If you really can't get it, try one of those bleeders that force fluid up to the master cylinder from the calipers/wheel cylinders.
Old 10-28-2011, 08:20 AM
No offense! This one has me stumped, any help is appreciated.
The front bleeders are sort of in the middle of the caliper, but above the line in.
I'm going to try bleeding everything again including the RABS (which I haven't done).
Old 10-28-2011, 08:36 AM
rattleNsmoke's Avatar
rattleNsmoke rattleNsmoke is offline
rattleNsmoke is gaining momentum as a positive member of FTE.
You just solved your own problemo. Bleed the RABS unit too. I bet you've got trapped air in it. I would bleed down the RABS, then the rr\, then l\r, then r\f, then RABS again, then l\f. Always start farthest from master cylinder and work toward it.
Old 10-28-2011, 08:41 AM
Sand_Man's Avatar
OK, there's a term I've never heard. What's a RABS? Where is it at and what does it do?
Old 10-28-2011, 11:00 AM
Bled the RABS then Rear and Front, no trapped air, no difference.
I'm going to try one more time before I punt and send it to the repair garage
Old 10-28-2011, 11:06 AM
DavidB DavidB is offline
DavidB is gaining momentum as a positive member of FTE.DavidB is gaining momentum as a positive member of FTE.
Suspect bad booster (leaking air) or bad vacuum line or booster valve.
Old 10-30-2011, 07:56 PM
countryboy73703's Avatar
countryboy73703 countryboy73703 is offline
countryboy73703 is starting off with a positive reputation.
I'm having a very identicle issue on my 05 f250 5.4 any ideas? and how do I bleed the RABS, i did't know that you could, also, if I'm going kinda fast, and then slam my brakes (VA drivers suck) then sometimes my front right side will lock up, until I push on the brakes kinda hard again and then that side will release, almost cause me to drift off the road the other day doing about 60 mph... but I also have stiff pedal when engine is off, and then when engine is on, pedal slowly goes down until just a few inches from the floor... really need to get this fixed..
Brakes stayed bled for 24 hours. 79fordf100styleside 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-30-2017 10:06 PM
Help - E350 brake pedal goes to floor - only when running! Fords412 1968-2013 Full Size Vans 16 11-17-2016 02:31 PM
Brakes are not fun Dave145 1973 - 1979 F-100 & Larger F-Series Trucks 25 10-03-2016 08:32 PM
Diagnosing Brakes / Master Cylinder with Low Pedal AL` 6.0L Power Stroke Diesel 19 02-17-2016 01:54 PM
1995 F350 Brake Bleeding Problem 1Tonn 1987 - 1996 F150 & Larger F-Series Trucks 18 05-23-2011 09:23 AM
Tags
1999, bleeding, brake, brakes, caliper, engine, f150, f250, floor, ford, pedal, running, sidee, starts, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
