Drivetrain Identification Help 78 F250 4x4 - Ford Truck Enthusiasts Forums
Old 10-26-2011, 08:46 PM
wooddyusa's Avatar
wooddyusa wooddyusa is offline
wooddyusa is starting off with a positive reputation.
I recently bought a 78 F250 4x4 and need some help identifying the transfer case, trans and axles. Its a 4sp. 8 lug wheels. drum brakes all around. 390 v8. I have some pics I took of these items if that would help. I have a feeling this truck has been pieced together. The vin is actually for a 78 F150 2wd truck. Any ideas or thoughts? Its actually a nice old truck. Thanks
Old 10-26-2011, 08:59 PM
Deluxetruck's Avatar
Deluxetruck Deluxetruck is offline
Deluxetruck is starting off with a positive reputation.
You suspect right on the pieced together part, but thats not necessarily a bad thing. Pics would be easiest.
Old 10-26-2011, 10:52 PM
wooddyusa's Avatar
Thanks for the help. Here are a few photos I took this afternoon. I hope they help.
Rear End
Transfer Case
4sp Trans - Probably not such a good photo
Front End
Old 10-26-2011, 10:56 PM
kingford72's Avatar
kingford72 kingford72 is offline
kingford72 is starting off with a positive reputation.
looks like dana 60 rear, dana 44 front, np 205 transfer case (see the 3 bolt cover in the middle) and the trans looks like a np435, check the top gear shift housing if its alum its the np435 if its cast steel its a t18.
Old 10-26-2011, 11:16 PM
wooddyusa's Avatar
Thanks Kingford.
Old 10-26-2011, 11:38 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Quote:
'73-'75 highboy chassis with a later cab/bed swap.
Old 10-27-2011, 12:20 AM
buttwheat's Avatar
buttwheat buttwheat is offline
buttwheat is starting off with a positive reputation.
Did they have the 390 in '78 or had they gone completely to the M blocks 302,351,400?
Old 10-27-2011, 01:19 PM
wooddyusa's Avatar
Nice so I may have ended up with a highboy afterall. I was told the 390good was put in in the 90s.
Old 10-27-2011, 04:06 PM
Blackfoot Big Block Blackfoot Big Block is offline
Blackfoot Big Block is starting off with a positive reputation.
Good Eyes, MT!
At first I thought "How did he know it wasn't a '76 or early '77"? but after studying the photos I could just make out the closed knuckles on the front axle.
To the OP,
That truck never came from Ford with a 390. The only V8 offered during the '73-'75 F-250 4x4 era was the 360. Externally you can't tell the difference, and many a seller has "magically upgraded" the engine to a 390. The only way to be sure is to measure the stroke of the engine.
Old 10-27-2011, 05:37 PM
wooddyusa's Avatar
This probably explains the gas tank being in the cab. Thanks for all your help.
The only way to really know what year it is is to find the VIN on the frame right? Now if I find it should I try and get the title changed? Any pros or cons to doing that? Is there a number on the engine that might confirm its a 390 or a 360?
Old 05-20-2013, 06:56 PM
wooddyusa's Avatar
Can someone explain what closed knuckles means?
As I posted in a new post today...I'm having some issues and am trying to learn as much as I can to start working on it. Thanks.
Old 05-20-2013, 07:09 PM
wooddyusa's Avatar
I just found the answer to my question in one of the tech links about the closed vs open knuckle.
Would it be better for me to try and find an open knuckle axle locally?
How would I identify what the gear ratios are in the front and rear?
They should be the same correct?
Thanks. TJ
1978 F250 Leveling Kit Question 78fourby4f250 1973 - 1979 F-100 & Larger F-Series Trucks 11 11-04-2013 11:54 PM
Part search help - Steering TRE - 78 250 eb76adam 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-17-2012 11:56 PM
Did Ford make a 78/79 F350 4x4 itlkick 1973 - 1979 F-100 & Larger F-Series Trucks 164 05-03-2010 06:17 PM
Was 78 the first year for Supercab 4x4?? Dads79 1973 - 1979 F-100 & Larger F-Series Trucks 13 01-10-2005 06:50 PM
Using 78 F150 4x4 body parts onto a 71 F250 4x4 71fordhopeful 1967 - 1972 F-100 & Larger F-Series Trucks 5 05-25-2004 08:30 PM
Tags
1967, 1997, 390, 4x4, 78, axle, case, drivetrain, drivetrains, f150, f250, ford, frount, id, identification, put, ranger, transfer, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
