Q: 1988 Dual Tank Fuel Pumps Operation - Ford Truck Enthusiasts Forums
Old 10-26-2011, 04:49 PM
quisp quisp is offline
quisp is starting off with a positive reputation.
1988 F150 Lariat SB 5.0 EFI Dual Tanks.I have the "Low pressure pumps" in both the Rear, and Side tanks, and a Hi-Pressure Pump" on my frame rail- Now, I Understand that I have a "Fuel Resevoir " of sorts that holds un-used fuel that was sent to the Fuel rail,Does anyone know much about this system, ?? I believe I have some contamination in the rear Tank, It has about eight gallons of gas in there, -when the motor begins to sputter, I switch it to the Front tank, and it straightens out, stops sputtering, and poppin'Switch it back to the rear tank, and within a couple of minutes, it starts sputtering agin. Then I click it back to the front to keep it from dyin.I dont use the front tank much because it has a leak, But for some reason, after a couple of days or so of driving, It seems to accumulate Fuel..?Is this the Fuel being sent back to the Fuel resevoir, and back into a Tank?Because It seems that whatever is in the rear tank, is slowly making its way into the front tank, possibly from this By-pass to the Fuel Resevoir?Can anyone clarify this for me? Thanks
Old 10-26-2011, 04:59 PM
mpc07005's Avatar
mpc07005 mpc07005 is offline
mpc07005 is starting off with a positive reputation.
That "fuel reservoir" Is also called the 6 port reservoir switching valve. It is before the High pressure pump, and has 2 lines to each tank and 2 to the engine, 1 supply and 1 return each. When that Valve fails, you get 'cross flow' which is mostly return to the wrong tank, but can be pumped in from the other tank. Check the wiring to the rear sender (low pressure), and if you think the rear tank is contaminated, get that gas out. The cross flow means you need a new selector valve, but if you have no intention of using the midship tank, you can bypass it.
-Mike
Old 10-26-2011, 05:07 PM
I see how this works, -thanks mike, -gotta get the bad gas out.
Front fuel tank issue and 'name that part' sloppyslim16 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 05-15-2015 06:46 PM
1988 f150 300 6 dual tank pumps not running jskeith47 1987 - 1996 F150 & Larger F-Series Trucks 3 01-24-2015 02:46 PM
Question on fuel selector valve - dual function reservoir SSellers 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 12-24-2013 01:47 AM
1996 fuel pump question LADNAR 1987 - 1996 F150 & Larger F-Series Trucks 5 02-24-2011 10:24 AM
Help, truck won't start CaptMorgan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 05-23-2010 06:32 PM
Tags
1988, 88, 96, at, dual, f150, f350, ford, fuel, gas, pump, tank, tanks, tankswhere, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
