Third brake light leaking please help - Ford Truck Enthusiasts Forums
Old 10-26-2011, 02:54 PM
bri687 bri687 is offline
bri687 is starting off with a positive reputation.
Well I have a leak coming from the third brake light and was wondering what can I use to seal the leak up? I already replaced it once because of a crack. Also If I end up replacing the light is there a better alternative?
Old 10-26-2011, 03:01 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
If you can locate a sealant, silicone or another type, that is safe for use on clearcoat, then you can apply a bead of it along the underside of the light and re-install.
Old 10-26-2011, 03:03 PM
Quote:
Is there such a thing as clearcoat safe silscone?
Old 10-26-2011, 03:24 PM
MCDavis's Avatar
There might be...I haven't found it. People have used a variety of things. Most without reporting any damage.
Old 10-26-2011, 04:14 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
I purchased a New light off Ebay and could of gotten the 3rd brake only for about $30 and it has the center lights as LED and then the factory side bed lights are reused and it just plugged straight in and looks nice. I have a picture of it in my album I think. They are Eagle Eye products and I have been happy with my purchase and no more leaks in the cab too.
Old 10-26-2011, 04:20 PM
MCDavis's Avatar
Here's an interesting read on silicone in automotive uses from the guys at Meguiars:
meguiars.com: FAQ - Are products that contain silicone bad for my car's finish?
Old 10-26-2011, 07:16 PM
well I might try this product to see if it works unless anyone see a reason not to.
http://www.permatex.com/products/Aut...sket_Maker.htm
Old 10-26-2011, 07:20 PM
cb_13's Avatar
cb_13 cb_13 is offline
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
If your leak is coming from the seal around the lamp assembly I recommend the permatex clear rtv silicone. You just need to seal out water not permanently attach the lamp to your cab. I have used the motorcraft on several occasions and this appears to be very similar if not the same stuff. Could also use teflon washers between the screw head and lamp or a small amount of the silicone. 80050 permatex part number
Old 10-26-2011, 10:35 PM
Quote:
Well I think the leak is coming from the gasket on the assembly. If thats where it's coming from do i use gasket maker or clear rtv silicone that you were telling me about?
I don't know much about sealants,adhesive and gaskets but i'm just looking for something that will stop the leak and be able to remove it in case of replacement.
Also should i remove the gasket before applying anything?
Old 10-27-2011, 07:52 AM
MCDavis's Avatar
Go with the clear RTV. Also dab a little bit around the screw holes on the exterior of the light before you put the screws back in.
Old 10-27-2011, 01:55 PM
cb_13's Avatar
+1. I leave the gasket on the the lamp and apply a bead over it before putting it back on the truck.
Old 10-27-2011, 10:58 PM
Well I put the sealant on the gasket and now gonna let it dry.
Thanks for the help everyone, now well see how it works.
Old 10-28-2011, 03:50 PM
yellowboy's Avatar
yellowboy yellowboy is offline
yellowboy is starting off with a positive reputation.
I gave up on farting with mine, just put a BIG bead around the outside. Unless you are 7 foot tall, can't see it.
For 30 grand and up you would think the Ford idiots could keep a light from leaking. No wonder the Japs are doing well.
Old 10-28-2011, 08:11 PM
cb_13's Avatar
You are so right Toyota has never had any recalls or problems ever. I have an 04 that i got used so i have dealt with alot of very frustrating little problems but i will guarantee you that every make has their own issues.
Rear lights ground question steve2z Excursion - King of SUVs 13 12-28-2016 10:33 PM
3rd brake light leaking cdwoodcox 2009 - 2014 F150 9 08-19-2015 05:11 PM
Wiring Headache Rack ReezyF250 1999 to 2016 Super Duty 5 03-04-2012 09:36 PM
third brake light northernz 1999 to 2016 Super Duty 12 11-25-2011 11:04 PM
1991 Ford F 150 XLT Lariat 4X4 Utility/Third Brake Light???? txjason1 1987 - 1996 F150 & Larger F-Series Trucks 14 06-16-2009 04:56 PM
Tags
2001fordrangerleaks22brakelight22, 3rd, back, brake, explorer, f150, f250, ford, fordf150leakingthirdbrakelight, forum, leak, leaking, leaks, light, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
