Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > California, Southern Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
California, Southern Chapter Join Chapter, Leader: wpnaes
  #1 (permalink)
Old 10-26-2011, 11:38 AM
timbuctooCal's Avatar
timbuctooCal timbuctooCal is offline
1990 ford E 250
My Garage
timbuctooCal is starting off with a positive reputation.
E350 switch trans from A/T to manual
My E350's AT is beginning to fail. Although I liked having A/T, Im wondering if a manual would suit my needs better.
The only thing i dont like about the A/T is on a mildly steep off road crawl from a dead stop the trans just wont budge the rig along.
A manual floor w/ granny will move it along like Id like.
Im not a fast mover in the thing. I just poke along and dont like to tear things up or have every cupboard inside dump their contents on the floor.
Insterad of getting a rebuilt AT id just as soon find some shop to install a used manual in it.
I'd like to know some of the opinions from those of you with some knowledge/experience etc on the feasability getting this done. pros cons?
Any shop in So cal experienced with this kinda conversion and has a good reputation?
  #2 (permalink)
Old 10-26-2011, 12:17 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
2006 Ford F-250
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Bill Pounds
Quote:
Originally Posted by timbuctooCal View Post
This was an E250 "Factory"Camper Conversion FSC (self contained)by Coachman then I had Kroeger Conversions in Redding install the 350 chassis with a 4x4.
I don't know about converting to a manual. Probably pretty tough on a van chassis with doghouse. But I'm wondering why you don't use low range for creeping along. Or did you not get a transfer case with low range when they did the conversion? Or maybe it is, and you just don't have the shifter in the cab?
__________________
Folks call me Bill. Why, yes, it is a 6 liter. Your jealousy is showing.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back (w/CAT),Edge Insight CS,Blue Spring,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto,'08 Diff Cover,Upfitters Retro-fit,Coolant Filter,Custom Man Steps,Keystone 2011 Cougar 278RKSWE,2012 Fusion SE
  #3 (permalink)
Old 10-26-2011, 01:08 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
That's a C6, right?
A well-built C6 is darn-near bullet-proof, and will save you a buncha' grief with converting!
Pop
__________________
-Marv- one of The Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks, and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, spin-on hydraulic filter, coolant filter, 6637 & cover, bypass lube oil filter, HPX, Hutch n' harpoon.
Email SpringerPop SpringerPop's F-350
  #4 (permalink)
Old 10-26-2011, 03:31 PM
85e150six4mtod 85e150six4mtod is offline
Garage is empty, add now
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
You can also put a wide ratio gear set in a C6, although it's not a cheap proposition.
If you have to smog this thing, you will run into troubles with a MT unless it was offered with one from the factory.
  #5 (permalink)
Old 10-26-2011, 09:22 PM
1990 ford E 250
My Garage
Quote:
The low is ok for creeping around,except some steep hills,if I come to a stop,the truck will not move forward .
It has a low range TC. Shifter is in cab.
maybe theres something wrong with the A/T?
  #6 (permalink)
Old 11-01-2011, 11:39 AM
1990 ford E 250
My Garage
uh oh here we go
Well i seem to have lost 1st gear only when the colum shifter is put into 1st.
If I then put it in reverse then back into 1st it works and I can then go fwd.
I ve posted this issue yesterday and so far views but no answers/comments.
  #7 (permalink)
Old 11-01-2011, 11:56 AM
bpounds's Avatar
2 bit Californian
2006 Ford F-250
Bill Pounds
Do you think that might be shift linkage? Worn bushings, or maybe just an adjustment?
__________________
  #8 (permalink)
Old 11-01-2011, 12:48 PM
1990 ford E 250
My Garage
Oh,I have no clue. I know absolutely zip on A/Ts.
  #9 (permalink)
Old 11-01-2011, 11:20 PM
OP should post what city he is in and ask for a good AT shop reference imo....
  #10 (permalink)
Old 04-07-2012, 12:20 PM
1990 ford E 250
My Garage
Yes it does have a low range.Just not low enough.
The issue I run into is that on steep inclines and from a full stop it will not respond as well and sometimes will not move the van at all up the incline compared to a manual.
However, the manual trans was in a regular 4x4 pickup which weighs 2000 lb less.
(van 8000lb)
The "granny gear was as I recall a much lower gear as i recall.
Otherwise i preferr A/T,excluding the above
  #11 (permalink)
Old 04-08-2012, 04:37 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
This Econoline 4WD conversion, who did it, Pathfinder, Quadravan or?
Did you have the 4WD owners manual, that also lists all the parts and their part numbers, what vehicle(s) the parts were sourced from?
Be aware that when Econoline were converted to 4WD, the conversion parts may/my not be from a FoMoCo vehicle.
If you don't have the manual, it will be a royal PITA figuring out what the parts are from.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #12 (permalink)
Old 12-17-2012, 11:42 AM
1990 ford E 250
My Garage
it was a conversion by Salem kroeger in NCal I had done many years ago.
All ford parts
  #13 (permalink)
Old 12-17-2012, 11:45 AM
1990 ford E 250
My Garage
my location
Im in the palmsprings area
Quote:
  #14 (permalink)
Old 12-17-2012, 08:20 PM
wpnaes's Avatar
wpnaes wpnaes is online now
FTE SoCal Chapter LDR
2000 Ford Excursion
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Wow, glad this isn't a rush job. That AT been hangin' in there pretty good after a year +. Didya give the cronies in forum 128 a try? They might have some fresh ideas.
1968 - Present Full Size Vans - Ford Truck Enthusiasts Forums
__________________
Sean
2000 Excursion XLT V10 4x4 170K, front V's, rear mod'd C's,, 315's, winch bumpers F/R, Viair system, Piaa lighting, Hellwig rear, dual Optimas, oily K&N, RedHeaded, scratchy paint, love taps at each corner.
Join the So Cal chapter here
  #15 (permalink)
Old 01-07-2013, 01:53 PM
Ford Parts Guru
2013 Ford Escape
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
