Brake Pedal moving Speedometer
I have a 2001 Ford F 450 truck and I'm having a problem with the speedometer
When I'm fully stopped, the speedometer jumps to 20km/h when I'm holding down the brake. I let go of the brake and it goes to normal, I full brake again and it jumps to 20km/hr at a full stop. There is no revving at all either if it matters.
Could someone please tell me the problem and how to fix it? Thanks.
Is this a constant problem, or intermittent?
Is is always 20km, or is that value random?
As a first start, I'd have someone apply-release-apply-release the brakes while tracing the brake lines beneath the truck to be sure there's not some point of movement in the lines.
I'd also look to be sure the lines are corroded, and that there aren't any obvious fluid leakage points, and see if the master cylinder level is down.
I would have thought the speed sensor would be somewhere alongside the drive shaft. If you can find it, see if its loose?
Not to say this is an unusual problem, but if you don't find anything with your inspection, I think I'd be inclined to contact a priest and arrange an exhorcism!
1977 f-350
09-12-2010 03:43 PM
