Turn Signal Problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Turn Signal Problem
Old 10-25-2011, 08:45 PM
fishdip fishdip is offline
fishdip is starting off with a positive reputation.
Turn Signal Problem
So I have an issue with my fuse that controls my turn signals and brake lights. It start with when turning on the left hand turn signal the fuse would blow now that I have done some work on it to find the issue when I put a fuse in it blows with out the truck running or anything.
What I have done:
  • Checked the light bulbs
  • Checked the light bulbs connectors and assemblies
  • Disconnected the Trailer assembly
  • Taken apart the steering cloumn and checked the switch assembly (this is when the problem got worse)
It is a 2004 F350
Old 10-26-2011, 09:18 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Welcome to FTE.
Sounds to me like you have a wire that is chafed and grounding out.
Left Turn Signal Wont Work Z7Hunter 1999 to 2016 Super Duty 2 01-27-2013 12:54 PM
Left Turn Signal not working Z7Hunter Electrical Systems/Wiring 2 01-27-2013 12:27 PM
Turn Signal Switch Problem ??? The Postman 1999 to 2016 Super Duty 3 07-27-2011 09:45 AM
Blowing turn singal fuse when put into reverse Charlie01 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 12-18-2010 04:16 PM
69 F-100 turn signal problem brucelee Electrical Systems/Wiring 4 07-26-2004 10:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
