Exhaust Manifold Studs Broken :-( - Ford Truck Enthusiasts Forums
Old 10-25-2011, 08:00 PM
ggazz50's Avatar
ggazz50 ggazz50 is offline
ggazz50 is starting off with a positive reputation.
Well it finally happened to me. I got this truck brand new (2002 F-250 Lariat CC SWB 4X4 V10) and it's only got 30,000 miles on it! I heard a slight exhaust leak so I checked it out and found that the two upper stud nuts were rusted off on both sides and possibly the lower ones also. I was wondering if I should go with the SS replacement studs or should I go with SS bolts instead of the studs? What do ya'll think? Thanks.
Gene
Old 10-27-2011, 12:33 PM
samdad02 samdad02 is offline
samdad02 is starting off with a positive reputation.
SS studs. I couldn't get my parts guy to look for SS nuts and washers so I went and found my own. I hear you need to check the stock logs for twisting also. good luck it's a lot of fun if you do it yourself!
Old 10-27-2011, 04:15 PM
Sand_Man's Avatar
Sand_Man Sand_Man is offline
Sand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud of
Correct me if I'm wrong, but aren't the stockers stainless? I also agree that if you have to remove the manifolds, a trip to the machine shop to have them surfaced is money and time well spent.
Old 10-27-2011, 10:09 PM
samsdad02 samsdad02 is offline
samsdad02 is starting off with a positive reputation.
Neither studs nor nuts were SS on mine. The 1st ones the parts guy pulled out were black. After some poking around on fte I got the SS stud part#. But had to find my own nuts and washers.
Old 10-27-2011, 11:38 PM
ggazz50's Avatar
SS Short Headers
Does anyone have any experience with this product or opinions on these? They come with all hardware and gaskets for $180 shipped. Thanks <=> FORD F250/F350/EXCURSION 6.8 V10 STAINLESS STEEL HEADER | eBay
Old 10-28-2011, 06:58 AM
Similar to what I ended up getting I didn't use the supplied hardware
Old 10-28-2011, 04:09 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
Do a search on ebay headers.
Many have installed. Some had issues with cracking after a couple years.
Old 10-28-2011, 08:59 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
i'd avoid em..
getting what you pay for and all that, dealing with cracked headers is even worse then dealing with snapped off exhaust studs.
spend the money and get a quality set of headers or just replace the studs with quality SS bolts.
5.4 Exhaust Studs Coachhick 1999 to 2016 Super Duty 8 08-22-2016 10:48 AM
Dreaded manifold studs....quick question. 44dwarf Modular V10 (6.8l) 4 08-05-2016 10:46 AM
Turbine Inlet Studs SgtRauksauff 1994.5 - 1997 7.3L Power Stroke Diesel 2 04-12-2016 10:50 AM
Intake studs JoeDaf Ford Inline Six, 200, 250, 4.9L / 300 10 10-30-2011 01:35 AM
1997 F150 4.6 exhaust manifold repair Rebel64 Exhaust Systems 2 05-14-2009 04:13 PM
Tags
1979, bolts, broken, exhaust, explorer, f150, ford, inline, manifold, rusted, slc, studs, studsbroken, sutds, ut, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
