Cold starting issues again, continued - Ford Truck Enthusiasts Forums
Old 10-25-2011, 06:40 PM
77-250 77-250 is offline
77-250 is starting off with a positive reputation.
A few months back I posted about some long cold crank times I was getting and some intermittent running issues. Well, the cold start issue seems to be getting worse. I don't drive the truck everyday, but 2 weeks ago I left in the morning for a 250 mile round trip to pick up an old Honda CB750 and it cranked for what seems like forever and finally started, and I thought to myself this is going to be a great trip and left. Long story short it seemed to run fine, and started ok when hot. I went to move the truck again last week, and again long cold crank, finally started in a cloud of dark black smoke. I figured I should check FICM voltage. I left it sit til today, I connected my volt meter and checked the voltage when the injectors buzz, it went down to about 30 volts and the injectors stopped, and voltage went back to 48, I did this a few times before starting it, same results. I started the truck, and this time it started pretty quick (suprised), and once running the voltage stayed around 45 volts, and would drop a bit to 44 or 43 when you increased engine speed to about 2K, voltage would not get back up to 48 volts. So is the FICM failing? I thought the voltage should stay at or around 48 even when the injectors are buzzing?
Thanks! (sorry for the long story!!!!)
Old 10-25-2011, 06:49 PM
a2elvis a2elvis is offline
a2elvis is starting off with a positive reputation.
Yep needs a FICM repair or new power supply. The voltage should hold steady at 48V all the time. I will give alittle and say 47V ok but not 30V. Get the FICM repaired or replaced
Old 10-25-2011, 07:04 PM
grantpage grantpage is offline
grantpage is starting off with a positive reputation.
I agree the ficm is probably failing, but I would definately make sure the glow plugs are working before I went to far.
Old 10-25-2011, 08:23 PM
NewToDiesels's Avatar
NewToDiesels NewToDiesels is offline
NewToDiesels is gaining momentum as a positive member of FTE.
FICM is toasted... FICM Repair.com - Your Source for FICM Repair Good guy, great service...
I wouldn't drive it anymore. Could damage your $$$ injectors.
You can also look in the Tech Folder for a DIY, but be forewarned, if you mess up the board, most shops won't take it as a core.
Old 10-27-2011, 07:39 PM
Got the FICM out, pretty simple. Now I'm not sure who to send it too. I'm torn between swamps, and ficm repair . com. FR.com is cheaper, but I think you might get more from swamps, I'm not sure. From what I understand, swamps will reflash the FICM with the latest Ford flash, FR.com doesn't do anything with reprograming. What about the 58V "upgrade"? I can't see how a 10 volt increase will do any harm, or good?
Thanks!
Old 10-27-2011, 08:44 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Dont do the 58 volt mod
the injectors are designed for 48 volts
58 volt mod makes the FICM run Hotter its already in a hot spot doesnt need any more heat
With the 58 volt mod folks have reported when the Ficm goes it usually Dies without warning
I wouldnt do it but to each his own
Send it out to www.ficmrepair.com
Havent heard any complaints
Great customer service
Warrenties his work
Old 10-28-2011, 05:22 AM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
I just got one from FICMREPAIR.COM has worked great good service and Ed stefen great guy.
Old 10-28-2011, 06:07 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Quote:
Thanks!
If you have questions about your FICM repair then shoot Ed an email. He'll explain the benefits and downfalls of what you're contemplating in a very persuasive way. Getting the latest greatest Ford flash may or may not be the latest greatest thing to do for your truck. Powerhungry performance can reflash your FICM with some enhancements that make driveability and (usually) MPG's better.
Old 10-28-2011, 07:02 PM
Thanks guys, you helped me make up my mind.
Old 11-03-2011, 10:22 PM
FICMrepair.com FICMrepair.com is online now
SPONSOR
FICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to behold
What more can I say? You guys rock.
Ed
Ed@ficmrepair.com
Old 12-07-2011, 09:52 PM
Not fixed......
It turns out the rebuilt FICM did little to help my cold starting issue. It still cranks for about 5 to 6 seconds and fires off like nothing. No rough running, just like instant running. It gets better once its hot, which makes me rule out any high pressure oil leaks. I don't have any misfires or heavy smoke, which rules out glow plugs. One cold start I tried something different, I went right to off to start, didn't let it buzz or glow, it cranked for a second or two, and I could hear the injectors fire, and it started, rough, but faster than if I let it glow/buzz. I guess I was trying to rule out the glow plugs. I'm missing my owners manual and I'm not sure which fuse/relay to pull to disable the glow plugs.
Anyway, besides the starting issue, the truck seems to run great, no other problems or codes. I hate to throw parts at it, but I'm wondering if the rail pressure sensor is going bad? Anyone have an idea?
Thanks!
Old 12-08-2011, 07:23 PM
Injectors begin to fire at 500 PSI rail pressure, correct? What is the thread size for the pressure sensor? NPT?
Thanks!
Old 12-08-2011, 07:50 PM
BLADE35's Avatar
Yes thats what I have read injectors fire at 500 ICP
Do you have any gauges???
Dont rule out a HPO leak just yet it maybe Bleeding off what happens if you let it sit a couple hours and then start
Does it start better if you cycle the glow plugs a couple times B4 you start it up
Old 12-08-2011, 08:00 PM
I've got a livewire, but its pretty much worthless..... Seems like the scangauge is the best bang for the buck. I'd like to plum a mechanical guage and check the high pressure oil system.
Old 12-08-2011, 09:54 PM
BLADE35's Avatar
A scangauge can check the HPO it gets both ICP & IPR%
you only need a mechanical gauge if you suspect a bad ICP sensor
SG does do alot money well spent there
Huge battery drain from FICM JonnyRam 6.0L Power Stroke Diesel 4 11-11-2016 03:46 PM
7 pin FICM repair pjeitler 6.0L Power Stroke Diesel 18 11-11-2016 02:57 AM
FICM testing procedure bismic 6.0L Power Stroke Diesel 332 06-16-2016 12:45 AM
Stiction or something else... jeddi03 6.0L Power Stroke Diesel 15 04-16-2015 11:24 AM
Torque up and running, starting to find issues the_auto_tech 6.0L Power Stroke Diesel 10 10-31-2012 07:09 AM
Tags
1995, 351m, 58l, 60, blue, cold, diesel, f250, ford, great, issue, make, springs, start, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
