Cold starting issues again, continued - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-23-2011, 08:35 PM
77-250 77-250 is offline
77-250 is starting off with a positive reputation.
I started working on the truck this afternoon after work. I figured I would run out of daylight pretty quick so I decided to start on the drivers side. I managed to get the valve cover off pretty easy and pulled the first dummy plug, jackpot! The lower oring was blown out. They were the earlier plugs because they didn't have back-up orings. I pulled the standpipe upper pipe and the orings were ok, but they were still the old style. I wanted to pull the lower standpipes so I removed the oil rail, easy. Pulled the lower standpipe, seemed ok. I forget my 3/8 torque wrench, so I just put the oil rail back on and tightened the bolts hand tight. I'll torque the bolts later and install the new standpipe and dummy plug. I guess there isn't anything wrong with installing the standpipe in one piece. I'll finish up the driver side and hit the passenger side. Will report back!
Thanks!
  #32
Old 12-26-2011, 05:24 PM
I'm sorry to say, but I don't have good news.....I managed to get some time yesterday and finished up the drivers side, and started on the passenger side. This morning I got the PS done. The dummy plug and standpipe looked ok, but I replaced them anyway. The standpipe came out in one piece, which was good so I didn't have to pull the rail. I reassembled the truck and fired it up. It started after the second attempt and ran pretty good. Here is where is gets bad. I shut it off, and restarted the engine, it cranked a bit longer than I thought it should, but I thought it might have air yet in the rails because I only had it running a short time. I hit the high idle switch and left it fully warm up. I shut it down and left it sit a few. I went to restart it and it cranked a long time, probably 10 seconds or so, but it did start. It appears my leak is a lot worse now. I tried starting it again, same result. I'm thinking on the driver side rail, the injector orings must be leaking. The rail came off really easy, and it went back on with very little resistance. I'm thinking thats where the leak is. I highly doubt the orings got torn on assembly on the dummys and standpipes....grrrr.....
  #33
Old 12-26-2011, 06:30 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
you can run it with the valve covers off then you can see if it leaks at the injectors
  #34
Old 12-27-2011, 06:31 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Quote:
Originally Posted by 77-250 View Post
As far as the orings in the injector tops, you can't replace them right? Not a servicable part? I don't really understand that, I guess they want to sell injectors...
Thanks!
The injector o-ring kits are available from Clay@RiffRaff diesel that have the spool valve d-ring in them here: http://www.riffraffdiesel.com/mm5/me..._Code=F03-07-O
  #35
Old 12-28-2011, 08:31 PM
Great news! I talked to a buddy of mine that used to work at my location today. He has a `97 7.3, and when he did injectors he had the same trouble as me. He had to drive his truck for a few days before all the air was worked out. I started up the truck after work and left it on high idle for probably 45 minutes while I ate and took out the trash. I shut it down, left it sit a bit and restarted it. It started instantly! I went for a short drive and it seemed to run very well. Let it sit several minutes and it started up again very quickly. I'm very pleased! Also, my IPR duty cycle at idle, oil temp 188 was 22%, seems leak free to me. Tomorrow morning cold start will be the true test.
  #36
Old 12-28-2011, 08:37 PM
BLADE35's Avatar
You got it Fixed
IPR 22% at hot idel is Good as it gets your leak free
must just had some air in there
Iv noticed mine has passed an air bubble the next day 20 miles later a few WOT runs should help purge the air from the HPO rails
  #37
Old 11-02-2013, 09:45 AM
FICMrepair.com FICMrepair.com is online now
SPONSOR
FICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to behold
Got the FICM out, pretty simple. Now I'm not sure who to send it too. I'm torn between swamps, and ficm repair . com. FR.com is cheaper, but I think you might get more from swamps, I'm not sure. From what I understand, swamps will reflash the FICM with the latest Ford flash, FR.com doesn't do anything with reprograming. What about the 58V "upgrade"? I can't see how a 10 volt increase will do any harm, or good?
Thanks!
Glad to hear you got your truck going again! Something you mentioned earlier that I wanted to clear up - ficmrepair.com absolutely does do re-programming. We can do any revision of software that Ford ever produced or, for a far better experience, can tune with any PHP tune. In fact, we just started offering PHP's ECM tuning... (need to get the website updated to reflect that last bit).
We stopped doing voltage mods to the modules a few years back when it became clear that reliability was hit pretty hard and that, more specifically, when the modules failed, they did so catastrophically - like leave you on the side of the road with a burning smell catastrophically - rather than fail gracefully.
__________________
Ed
Ed@ficmrepair.com
2005 Excursion 6.0 PSD. RAS, 4" MBRP T409, Edge Insight CTS, ScanGauge II, coolant filter, DELO ELC, upgraded FICM from FICMrepair.com, SCT, blue spring upgrade, trans bypass filter, Rancho 9000XL's, SS ESOF lines, Rotella 5W40, Clifford Remote Start, Prodigy.
Huge battery drain from FICM JonnyRam 6.0L Power Stroke Diesel 4 11-11-2016 03:46 PM
7 pin FICM repair pjeitler 6.0L Power Stroke Diesel 18 11-11-2016 02:57 AM
FICM testing procedure bismic 6.0L Power Stroke Diesel 332 06-16-2016 12:45 AM
Stiction or something else... jeddi03 6.0L Power Stroke Diesel 15 04-16-2015 11:24 AM
Torque up and running, starting to find issues the_auto_tech 6.0L Power Stroke Diesel 10 10-31-2012 07:09 AM
Tags
1995, 351m, 58l, 60, blue, cold, diesel, f250, ford, great, issue, make, springs, start, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
