Need Help With Dimensions..... - Ford Truck Enthusiasts Forums
Old 10-25-2011, 03:55 PM
modelmantru modelmantru is offline
modelmantru is starting off with a positive reputation.
I know I've asked for help on this in the past, but thought maybe someone had some new information on the dimensions of a 1957 Ford F-750 cab..... I build scale model vehicles from scratch, and am currently working on a 1957 F-750 Dump Truck, that I need the Cab dimensions for..... Width, Length, and Height, etc...... ANY help would be appriciated........
Old 10-25-2011, 05:52 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
The information you need is found on the schematic drawings contained within the 1957 Ford Body Builder's Layout Book. I have the only copy I know of for the 1957 range of models. The pages are large and the small print measurements aren't very readable when scanned. I've been asked to make it available for creation of a pdf file or CD but would rather not do that because it could then be turned into a profit maker for somebody. I will, however, give you full size copies of the two F-750 pages. The data is readable on the full size copies. If that works for you please email me at stu_sandymcmillan at sbcglobal dot net. I'll need your name and mailing address. Stu
crew cab frame dimensions needed Earnie Rosenow 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-13-2016 08:18 AM
2003 F150 Front Bench Dimensions Resto 1997 - 2003 F150 1 05-31-2016 08:24 PM
Box / Cab height dimensions camptramp 1999 to 2016 Super Duty 1 09-01-2015 06:24 AM
1957 F100 Bed scooner 1957 - 1960 F100 & Larger F-Series Trucks 4 01-30-2014 11:11 AM
49 F1 inside cab dimension moejr 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 08-23-2013 03:38 PM
Tags
1957, 73, cab, dimensions, drawings, f100, f750, ford, parts, scale, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
