Distributor question
The distributor gear has 11 teeth. Say that the hole for the roll pin aligns with one of those teeth on one side, then it is between two teeth on the other. So if you spin the gear 180, you are automatically 1/2 tooth off on your timing. Or the timing would be 360/11/2 = 16.36363636363636 degrees off if you want to be precise.
Ross, I see you have been doing your math homework. 16 degrees is not much and if it hit anything you could pick up the distributor and set it a notch over. You are right about the pin and the tooth, I dont have a mark to check mine but see if this if right, the hole aligned with the tooth faces the flat on the top of the shaft that holds the rotor.
backbonejay
04-12-2013 04:31 PM
