6x6 Tandem Axle question
What is the brake rotor/caliper do on the differential on this truck? It appears very similar to the middle drive axle.
http://www.cardomain.com/ride/264582...-3500-quad-cab
While that is also correct the real answer is because the brake being on the pinion uses the mechanical advantage of the gearing to help stop the tires.
Basically one rotor/caliper combo would be 1:1 if it were on the end of the axle like in most all conventional truck axles and its 6.72:1 being on the pinion of a 2.5t rockwell axle.
The simple/quick answer is because the gear reduction from braking the pinion is not needed on a 1/2-1ton truck . Its also known for putting foreheads through windshields when you push the pedal a little too hard.
There are a few companies selling brake kits like thisbut they are most commonly mounted at the t-case and are usually for a parking brake only. It would work for a regular brake though - provided you have one on the front AND rear output AND you ran in 4wd ALL the time.
on
A pinion brake as such has multiple disadvantages, one being rotor speed, with a 46" tire, the tire and wheel brakes would have been turning 446 revs per mile, but, with the rotor turning at driveline speed, you multiply that by 6.72, making it turn 2997 revs per mile. At 60 mph, the rotor is turning at what would be over 400 mph wheel speed. This quite obviously is extremely hard on any brake components you might put on there.
The other disadvantage is without a locked/spooled differential, if one wheel looses traction you might as well not have any brakes at all on that axle.
Pinion brakes are OK for a low speed trail rig, or as a parking brake setup, but they are definitely not something I would recommend for road use.
i could talk about pinion brakes, but pretty much all i know got covered already. plus, op, pinion brakes are not d.o.t. approved in any states as far as i know because of the reasons mentioned in here. people go with them as they are a cheap braking option and also shave a ton of weight off of rockwell axles. you can buy standard hub type disck conversions for rocks, but they aren't cheap.
