'93' F150 Powersteering pulley removal
Old 10-25-2011, 11:24 AM
straightsixer's Avatar
straightsixer
straightsixer is offline
so, this is the first time i've seen such a critter. The power steering pump shares a beefy cast aluminum bracket with the AC pump and I need to remove the PS pump. The PS pump is bolted to one side of the bracket and the pulley is attached on the other side of said aluminum bracket. Obviously the pulley needs to be removed before gaining access to the bolts holding the PS pump to the aluminum bracket. Question, how does this pulley come off and do I need to remove the entire cast aluminum bracket inorder to get to the pulley. I don't see a bolt keeping the pulley attached to PS pump??
Old 10-25-2011, 11:27 AM
White Max's Avatar
White Max
White Max is offline
You need a power steering pulley removal/installation tool set. Your local auto parts store should be able to rent one to you if you don't want to buy it.
Old 10-25-2011, 11:40 AM
straightsixer
Thanks White Max, i'm assuming its much easier with the bracket and all out of the truck, a little more work but oh well.
Now how about re-installing the pulley onto the new pump? I think i read somewhere on the forum about freezing the pump and heating the pulley...
Old 10-25-2011, 11:59 AM
White Max's Avatar
White Max
Honestly, it's about the same either in the truck or in a vise. Freezing the pump and heating the pulley (slightly...don't take a torch to it) helps, but you'll still need to use the installer tool.
Old 10-25-2011, 01:14 PM
straightsixer
Hey, I went to YOUTUBE and there was a video of my exact model of truck and you were right WM, this guy left the bracket in the truck and did the swap right there. He just had to loosen and move the fan shroud off to the side a bit. Looks like i know what i'll be doing this weekend.
1994 Ford F150, 302, 5.0 Power Steering Pump and Belt Change - YouTube
Old 03-09-2013, 12:38 PM
Brad.B's Avatar
Brad.B
Brad.B is offline
thanks guys i was wondering the same exact thing
Jesse Zimmerman
06-23-2009 04:51 AM
jurban
06-02-2009 04:50 AM
cdorroh
23
03-28-2005 10:48 AM
packratF350
12-19-2004 07:35 PM
creeksider
05-29-2000 09:08 AM
Quick Reply: '93' F150 Powersteering pulley removal
