front brakes dragging ' F350 58k - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-25-2011, 10:16 AM
rick52 rick52 is offline
rick52 is starting off with a positive reputation.
my front brakes seem to be sticking. I pulled the wheel off and rotor turns by hand but is dragging. Is it supposed to be touching the brake pads??
Old 10-25-2011, 01:31 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Grease the slide pins on your calipers. Those pads should be right up agains't the rotor but no much that it creates a drag.
Old 10-25-2011, 02:46 PM
Boss08v10's Avatar
Boss08v10 Boss08v10 is offline
Boss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to behold
My front passenger side rim is always dirty with brake dust before the other three, the truck does not pull one bit and it does not seem to be dragging. I know my 06 psd had a much different feel to the breaks and this 08 takes more pedal pressure. Not sure what to look at or fix. 53000 miles on the truck.
Old 10-25-2011, 04:58 PM
jbrunel jbrunel is offline
jbrunel is starting off with a positive reputation.
My 02 f-250 had a problem with the right front also..It turned out to be the caliper not fully retracting
Old 10-25-2011, 09:17 PM
ampslw ampslw is offline
ampslw is starting off with a positive reputation.
try this
take the brake cappler off and take one brake pad and a big c-clamp and push the piston back in
now it will take a bit of force but not a lot if it is very hard to get the pistons to go back in replace the cappler
now after that Grease the slide pins on your calipers
Quote:
<TABLE style="BORDER-TOP-WIDTH: 0px" class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR title="Post 10960742" vAlign=top><TD class=alt2 width=125 align=center>senix</TD><TD class=alt1>Grease the slide pins on your calipers. Those pads should be right up agains't the rotor but no much that it creates a drag</TD></TR></TBODY></TABLE>
Old 10-25-2011, 09:18 PM
try this
take the brake cappler off and take one brake pad and a big clame and push the piston back in
Old 10-25-2011, 09:20 PM
try this
Old 10-25-2011, 09:42 PM
FireMe FireMe is offline
FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.
You also need to make sure the pads are not binding in the caliper bracket, which is also common. The pads should be able to move fairly freely. If not, remove the pads and shims and then grind away any rust in the notch where the shims sit on the bracket. Put caliper slide grease on this cleaned surface, NOT on top of the shim where it touches the pads. Reassemble, pump the brakes a few times, and check to make sure the wheels rotate freely.
Jay
Brakes Dragging hermannm2 2009 - 2014 F150 5 08-15-2016 05:05 PM
2000 F350 Superduty front brakes dragging RJB71 1999 to 2016 Super Duty 15 10-09-2014 01:29 PM
Front brakes dragging, squeal... Mike in PA 1999 to 2016 Super Duty 9 05-05-2014 08:21 PM
brakes dragging Stangrcr1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 08-19-2012 11:44 PM
front left brake caliper dragging AKfordtruck 1987 - 1996 F150 & Larger F-Series Trucks 2 07-29-2010 06:41 AM
Tags
04, 1999fr450fordsuperdutyleftfrontbrakedrags, 1999fr450fordsuperdutyleftfrontbrakedrags3f3f3ffor um, 2001, 2003, 350, 450, brake, brakes, drag, dragging, f250, f350, ford, fordtruckbrakesdragging, front, slight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
