2001 F450 7.3 doesnt have full power. loads up/smokes
Old 10-25-2011, 06:25 AM
matt9923's Avatar
matt9923
matt9923 is offline
I have a 2001 F450 7.3 turbo. Its fine when you're not on it hard. When it gets warm and you want more then 1/2 to 3/4 of its power it loads up, loses power and smokes white.
Did buzz test all pass
got 4,6,7 contribution faults
self test 1/2 ran good other 1/2 ran worse.
Everyone keeps saying its the valve cover gaskets shorting out.
Old 10-25-2011, 06:49 AM
riverrat41's Avatar
riverrat41
riverrat41 is offline
Old 10-25-2011, 09:49 AM
matt9923's Avatar
matt9923
matt9923 is offline
Originally Posted by riverrat41
Here is a thread for that.Any codes?
https://www.ford-trucks.com/forums/9...rpms-long.html
Did tests using Snap-on Modis
Got EGR presure contol valve code. cleaned the pressure sensor tube and put in new sensor, didint help. Where is the EGR on a 7.3? Im somewhat new to diesels.
There was a ICP code.
3 cylinder contribution faults
and a low boost pressure one time but went way.
I get a service engine light and then it runs like crap, but sometimes it starts to do it befor the light goes on. First i thaugh it was putting it in limp moad?
Acts like its starving for fuel.
replaced filters...
Old 10-26-2011, 09:48 AM
matt9923's Avatar
matt9923
matt9923 is offline
it only starts under heavy load, going up a big hill when it shifts i give it more then it sounds like its stating to starve/ surge.
Old 10-26-2011, 09:57 AM
cj45lc's Avatar
cj45lc
cj45lc is offline
fuel filter good & have you checked the screens in the mixing chamber in the tank ?
checked fuel pressure ?
Old 10-28-2011, 06:16 AM
matt9923's Avatar
matt9923
matt9923 is offline
new filter, havent checked the screens. maybe do that this weekend.
how do i check fuel pressure on this motor? im somewhat new to diesels.
i found it... -
https://www.ford-trucks.com/forums/1...-pressure.html
Old 10-28-2011, 09:02 AM
izzybird's Avatar
izzybird
izzybird is offline
If your getting the light you need to pull the codes again. Does the smoke reek of raw fuel?
Old 10-28-2011, 09:45 AM
matt9923's Avatar
matt9923
matt9923 is offline
i got the scanner with me so next time it goes on ill plug it and see what im getting then post it up here.
ill see what it smells like, i was told white is lean and black is rich smoke
Old 10-28-2011, 10:27 AM
Duck Hunter81's Avatar
Duck Hunter81
Duck Hunter81 is offline
Have you ohmed out your connector to see if there are any shorts?
https://www.ford-trucks.com/forums/1...h-pigtail.html
See post 5.
Old 11-04-2011, 07:57 AM
matt9923's Avatar
matt9923
matt9923 is offline
i havent had any time with this storm up here. im still out of power. the truck didint move untill i could finally get diesel yesterday. Ill get back to it as soon as i have power in my shop.
Thanks for then help so far.
Old 11-17-2011, 06:24 AM
matt9923's Avatar
matt9923
matt9923 is offline
My main code is P0475, after clearing codes it come right back up.
I get nothing from my EBP while im driving. it just loads up and blows blue smoke.
i also got
P1316 IDM
P1211 ICP
PCM open/ short EBP
Where is my exhaust pressure regulator? on the turbo?
Old 12-02-2011, 05:20 PM
matt9923's Avatar
matt9923
matt9923 is offline
I finally got to working on my truck. about 2 weeks ago it got really bad and missed bad. So today i started checking some simple stuff.
i Ohm the gaskets and everything passes. gaskets are all around 3 and glow plugs were all around .8-1, i cleaned up all the connections and tightened the intake and cooler lines. I had some oil around the intake boot so cleaned and tightened it.
My waste gate doesn't seem to be opening at all. ill get up to 3k and it still wont move. I tried disconnecting the solenoid/sensor on the front of the block that goes to the wastgate actuator. i tried having someone run it while i held the gate open with vice grips but its hard to tell if its any better. i still see blueish smoke and i would like to see black, i think.
If anyone has any ideas let me know and is auto ingenuity the best tool to diagnose this? im not getting my service engine light as much blinked 2 times quickly tonight. but im thinking of buying one of those scanners. dealer is around the price of it just to diagnose.
I took it down the road after all this, it seems like its starving for fuel. I got on it, it still smokes white witch i was told means its lean and it surges. I'm going to check fuel pressure tomorrow and flow or just drop the tank and check screens.
any help is much appreciated. I have talked to a few mechanics and they told me pretty much the same thing. I'm 18 and i don't have much money to bring it in. I need my truck back!! Thanks
also i lost oil. underneath is a mess. doesn't leave any oil on the ground but its nasty. but oils going somewhere, maybe being burnt? would suspecting turbo or injectors be correct?
Old 12-03-2011, 12:08 AM
7.3 Rocket's Avatar
7.3 Rocket
7.3 Rocket is offline
How much oil are you losing and how quickly? Oil getting into the exhaust post manifold could explain white smoke. Does it stink like burning oil?
Try popping the intake off and checking the turbo. There should be no in out play and not enough up down play to contact the housing. Also the blades on the compressor wheel should appear sharp if they look like they were sandblasted it is a problem.
Old 12-03-2011, 10:58 AM
matt9923's Avatar
matt9923
matt9923 is offline
i lost probably a quart 1/2 to 2 in 2 months. the turbo is newer it has no play and is still sharp. i just had the lines off yesterday, had some oil in them. it only blows white/blue smoke when i'm driving, cant really smell it but it looks like oil burning.
Old 12-03-2011, 05:05 PM
7.3 Rocket's Avatar
7.3 Rocket
Oil in the Ic pipes is normal for a stock ccv.
Quick Reply: 2001 F450 7.3 doesnt have full power. loads up/smokes
