GT40-P Heads on a 94 351W
Some good reading in here: GT40P engine in Bronco - GT40P heads AND GT40P HEADERS that WORK - FSB Forums
Thanks, that was good information.
I rebuilt the engine right after I purchased the truck so my heads are fresh. I was just curious if anyone had first hand experience of putting them on a 5.8L. I would love to find a source for the preformed plastic vacuum lines. Mine are crumbing and I would love to put it back to a factory look instead of using rubber vacuum lines.
These are the vacuum lines I got for my truck. They are really nice lines. I made an attempt at building some hard plastic lines, but it looked crappy and I didn't like it. These lines should out last the plastic and be easier to work with down the road.
Silicone Vacuum Hose, Turbo Hoses, Vacuum Lines | Oomph Labs
just make sure your headers will work, thanks to smokin tatsch (posted pics of his) i could tell mine would work.
90* plug wires allow the p's to be used with virtually any Long tube header. I re-used my old wiress that have a pretty heavy angle to them, but I had to reverse 3 of them so the 90* boot (cap end) was on the header side. There should be no fitment woes whatsoever with 90* wires and p heads.
Ok, have never looked, but, if you wanted to run iron manifolds, could you use the explorer/mountaineer manifolds? I know the 5.8 has the EGR tube in the front, but do the outlets come anywhere close? The thought crossed my mind to use the GT40p's in my 86 5.0... My cousin has the truck now and there's no way in hell he'd want headers.
More restrictive than the stock 5.0 86 manifolds? The explorer was rated at what? 240hp or something? The 86 was only rated at 185 IIRC.
Welding's not a problem so a custom Y pipe isn't a big deal. Now that I found the Magnaflow Stainless Y pipe I'd do it all in Stainless and it'd be the last Y pipe ever needed.
I am probably one of the few on this forum that have actually run GT40P heads on a 351. First off is header fit, I have run two sets of headers on the P heads. First set was a set of summit shorty pacesetter headers. they fit besides a dimple that was required on the number 4 primary tube. And with a set of Ford Racing SS shortys. The ford racing headers required a shorty plug and a big *** dent in the number 3 or 4 primary tube. I cant remember. The stock valve springs in the P heads CAN NOT handle the lift of the Comp SD(Cant remember kinda drunk) cam that everybody recommends. They bind and break valve spring retainers in the exhaust side. Power was a bit better top to bottom compared to E7 heads. Low end was exceptional, bit they ran out of steam at about 4400 hundo RPM. That may have been and issue with the SD efi though. I have since moved on to AFR 165s a bit more of a roller cam and some other mods. Just be sure to have the head bolt holes reamed out to 1/2. Hell I had to do that with ONE of the AFR heads I got new in box. Still haven't sent them that dirty email. Any more questions?
