Wiring trailer hardness to explorer
Old 10-24-2011, 10:36 PM
Ranger4924's Avatar
Ranger4924
Ranger4924 is offline
Question Wiring trailer hardness to explorer
I have about given up!!! I bought a trailer with a four pin connector. I then when to Pepboys and bought the plug and go wiring hardness for my Ford Explorer $15.99. (One end, is round, has the factory connection which has 4 pins “males” and the other is the 4 pin flat connection) aka It is not the T-connection one. I plugged it in to the adapter on the left side under the taillight and got NOTHING!!! I check the other side and found the same thing but the factory connection on the right side had 6 holes for 6 pins and my adapter wound not go in!!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I then went down the street to Webb RV, After they looked through a few books the guy said something about ordering a part and that I would have to run a wire to my battery??? It would cost $65 dollars. WHAT!!!<o></o>
I then went back to Pepboys and bought the 4-pin flat wiring hardness (One end has 4 pin flat connection with 36” of extra wire for hard wiring. SO….. plugged the trailer connection and the 4 pin flat from my truck together…..I removed the left taillight, took the yellow wire (for stop light/ left light ) and connected it to the green wire out “middle blub” (There where three wires Black smallest, brown, and green) I attached the white wire to the frame of my truck and got NOTHING. The lights on the trailer work on my neighbor trucks. <o></o>
Can someone help me……….I have a 4 door 2000 ford exploxer<o></o>
Thank you<o></o>
Old 10-25-2011, 08:10 AM
caseys's Avatar
caseys
caseys is offline
xxxxxxxxxx
Old 10-25-2011, 08:51 AM
dan8052's Avatar
dan8052
dan8052 is offline
Check the fuse under the hood (drivers side). I had a simular issue with mine and it was the fuse.
Old 10-25-2011, 10:54 AM
Ranger4924's Avatar
Ranger4924
Question
Originally Posted by caseys
Have you taken a tester to the connection on the Explorer to make sure it is working properly (brake, turn signals, etc)?
Just wonderin'...
Yes, i tested all four pins. When I plugged in the tow ready adapter into the factorty adapter under my truck (it has what i believe to be a small led light) there was no power.
Old 10-25-2011, 10:56 AM
Ranger4924's Avatar
Ranger4924
Smile
In the reley box?????,
Do you know what the fuse number is?????
Old 10-25-2011, 11:05 AM
Ranger4924's Avatar
Ranger4924
Question Hardwiring????
I also still have the kit to hardwire, but i dont think doing it the right way.
What is the best way to find the right wire and the ground.
I could no find a ground post/hole/srcew or anything for the white wire???
I looked online but got little.
Old 10-25-2011, 11:12 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Use a test light or a DVOM (meter).... Any clean bond with the body or chassis will supply a ground.... Philip
Old 10-26-2011, 07:07 AM
dan8052's Avatar
dan8052
dan8052 is offline
Fuse #13... check it out, it's worth a shot! Here's a diagram of the fuse box: Where can I find a diagram or picture of a 1996 Ford Explorer fuse box? | Answerbag
Old 10-29-2011, 08:46 AM
Ranger4924's Avatar
Ranger4924
Thank you I think the fuse was loose so it work....got lights
GMoney1121
2017+ Super Duty
21
12-22-2023 10:23 AM
Mikes67F250
07-29-2018 03:19 PM
1fixitman
06-06-2018 07:20 AM
frankenherder
09-23-2007 08:26 AM
wejones
07-17-2006 12:56 PM
Quick Reply: Wiring trailer hardness to explorer
