Question about C6 Transmission
Thanks, you guys on here are great, and really helpful. Tom's 54
Really? Too old? Was the case broken? I think they just didn't want to work on it. The C-4 was introduced in 1964 and built until 1968 (according to wikipedia) and I just had a 1964 C-4 rebuilt here in Moore, OK. Total price with upgrades to hold the HP my modified 289 will put out and a custom torque converter built to match the cam specs was $900.
That being said, you will want to hook up the vacuum line to the modulator. It, in conjunction with the governor, helps the trans to shift at the right point and holds the lower gear longer under load to avoid lugging the motor. You are correct, 3 speed transmissions only shift twice because they start off in first gear.
The kick-down lever can be replaced with a cable from Lokar. They come with good instructions and are easy to install. I used one on my 289 and C-4 when I couldn't find a rod and bell crank assembly for a decent price.
I even called DVAP (yeah the guys from the TV show) and they wanted $250 for the kick-down assembly. I guess the TV show went to their heads. Either that or they think I'm from Europe.
Actually if you want to be technical the C4 was introduced in 1964 and produced only up until 1979 which it was then replaced by the C5 and used up until '82 which then was junked in favor of the AOD.
The C6 was made from 1966 until 1996, from the mid-80s on it was used primarily in the trucks behind the 460 and some 80s 351W H.O. trucks.
And not being able to rebuild it... BS! The C4 is the most widely rebuilt tranny next to Gm's TH350 and the Powerglide! The C4 is so popular the racing guys are ditching the heavy C6 in favor of the C4 because of all the advancements made to the C4 in recent years. C4s can be built nowadays to handle 1000+ hp and 1/2 the weight of a C6 that is comparable. I just had a c4 built, with a few upgrades to the tune of $650. If those guys would have told me that, i would have grabbed the tranny and never went back. What a scam.
That 260 you have really isn't worth much other than to a purist that needs one. Next time you go fishing, tie a rope to it and toss it off the bow and when you're done fishing, just cut the rope. You'll do yourself a favor. The 260 was 'ok' but has many oddities. For one, yes it's a smaller bore, a 3.80" bore compared to the more popular and standard 4" bore size of the 289 and 302 as well as 351W. The other thing was they were 5-bolt bellhousing blocks. The more common '66 and newer 289, and 302s were 6-bolt bellhousing blocks. No real aftermarket options for the 5-bolt blocks. Since it's coded for a Galaxie, there isn't a Galaxie guy I know of dumb enough to put a 260 back into a barge of that girth. Just about 95% of all smallblock Galaxies get the modern engine or FE engine treatment. Just thought I'd throw that out there.
On a side note, the 260 block itself might make a neat flower planter too.
The C4 was introduced in 1964, used in myriad 1964/81 Ford/Mercury Passenger Cars, 1965/81 F100/150's, 1965/79 F250 (I-6's), 1965/81 Econolines, 1973/77 Bronco's.
First year FoMoCo offered the C6 with the 302 as an option in F100/150's was 1978.
The C4 was all that was available (optional) in 302 equipped 1969/77 F100's, 1975/77 F150's, but since the C6 was an option over the C4 in 1978, either trans will be seen from 1978 thru 1981.
C5: Some 1981/83 F100/150 3.8L V6, 255/302 / Some 1984/85 F150 302 / 1983/85 Ranger 2.8L V6 / Misc 1982/86 Ford/Mercury Passenger Cars V6's, 255/302.
The AOD was the worst POS FoMoCo ever offered, worse even than the A4LD and that's saying something.
Introduced in 1980 initially for Passenger Cars, by 1986, the warranty costs to fix the terds EXCEEDED all the warranty costs for ALL FoMoCo A/T's COMBINED back to 1950!
Driving in heavy stop and go traffic, the constant shifting up/down .. in/out of O/D fried the AOD's guts, and it didn't take too long for this to occur, either.
Peeps towed trailers in O/D without a care in the world, until the AOD fried its guts, that is.
Many AOD's were repaired multiple times, due to salespeeps BS and the vehicles owners manuals that said to drive in O/D, without a caveat of any kind.
FoMoCo finally woke up, changed the owners manuals, warning about towing in O/D, ditto driving in heavy stop and go traffic.
Bill,
2 posts back:
My apologies, my typo. I have found Wikipedia to be accurate for the most part. A little slanted (depending on who wrote the article) but pretty good otherwise.
Dano78,
I hear you on the 5 bolt. Unfortunately my 289 and C-4 are of the 1964 5 bolt variety which is why the speed shop that built my motor could only use their dyno as a test bed and not actually tune it. Their clutch wouldn't fit inside the only bell housing I could find for the 5 bolt.
I had a 260 in a 63 Mercury Meteor station wagon and it proved to be a great motor. Powerful enough to tow my 14 foot boat and pretty economical with the single barrel carb. Good enough to go camping and boating in AK.
2 posts back:
Sorry, had a dyslexic moment. Ford produced the C4 until 1986 not 1968.
Dano78,
If there's talk of throwing a 260 out here, I'll gladly take it. My Meteor could use it. Or at least the draft tube, timing cover, motor mounts, and other external stuff.
C6 has more parasitical hp loss than the C4 does.
I never put a kick down rod on my '79 Bronco w/300cid and C6 swapped in, and never needed it, as there's enough low torque to get it moving. A 302's power band being in the upper rpm's, might need one, I don't know. But you can get away without one. My 2 cents.
Received 1,344 Likes
on
on
I hope the AOD isn't as horrible as portrayed up above - I just put
one in behind our 351W. It looked like the only way to get a true overdrive. (One note - It didn't work coming out the gate so it's already been replaced for another one - hmmmm.. Something to do with the pump I'm told).
Ben in Austin
Ben in Austin
Ben in Austin
Ben in Austin
sam
#28
Thanks Sam,
I had heard they need to be adjusted or you can wreck them pretty quick.
I wasn't familiar with the problems in stop & go traffic - We live in Austin that's about all there is going down 183 in the morning. So is there some restriction about being in Overdrive in stop & go traffic?
Ben in Austin
Ben in Austin
#30
Thanks Sam,
Ben in Austin
Ben in Austin
Like Bill said, best to keep it in "D" (3rd, no OD) in situations where it would be flopping back and forth from 4th. Adjustment of the throttle valve linkage was absolutely critical to preventing burnout, and the cable TV they went to in the '90's was much easier to adjust and keep adjusted. Unfortunately the only good way to adjust involves using a pressure gauge off a trans port under controlled conditions.
