redneck repairs
I used to be small time oval racer as well. I couldn't afford the longacre toe setting tools so I made my own tools to do the job. I cut 4 peices of 3/16th stainless steel plate big enough for the front tires to sit on. 2 Peices under each front tire. Them between both plates smeared gear oil between them so that the plates slide one one another. Jack up the front end and paint lines onthe tires with spray paint then used an old test light and scribed lines in the paint. Then sit the front tires on the plates. The oil between the plates helps the front tires and suspension relax.
sum_weirdo
15
09-01-2011 11:36 PM
Stone Mathews
1999 to 2016 Super Duty
09-24-2008 02:00 PM
