f700 weight - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
f700 weight
Old 10-24-2011, 09:12 PM
sth62691 sth62691 is offline
sth62691 is starting off with a positive reputation.
f700 weight
anyone have a guess at the actual weight of my truck for towing reasons? 1987, f700, 6.6, diesel 5 speed, no pto, day cab, chassis cab, full 50 gal diesel tank, air breaks, relay need a good guess of the actual weight thanks guys
Old 10-25-2011, 01:49 AM
80broncoman 80broncoman is offline
80broncoman is gaining momentum as a positive member of FTE.
All I can tell you is that the 94 F700 that I have weighs very close to 10K.
That weight was as a chassis cab. Factory double frame, 5.9 cummins engine, 6speed eaton, 22K rated rear axle, 10K front. air brakes, full 50 gallon fuel tank. 196 wheel base.
hope this helps.
Old 10-25-2011, 07:14 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The Certification Label will have the GVWR (Gross Vehicle Weight Rating) printed on it.
The 4th digit of the VIN defines the GVWR even further.
Old 10-25-2011, 02:00 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
He's talking tare weight.
Old 10-25-2011, 02:11 PM
Quote:
Correctamundo, but the only place the OP can get an accurate weight, is at a truck scale.
There's a gazillion differences between truck models, years, powertrains, fuel tanks, "back of cab" equipment and et cetera.
So, guessing what the weight could be, doesn't cut it.
Old 10-25-2011, 02:26 PM
You're right, the air breaks could make a big difference.
Old 10-25-2011, 02:31 PM
Quote:
Originally Posted by sth62691
air breaks.
That's the breaks...or is it brakes?
The most commonly misspelled word associated with vehicles on FTE is brakes.
Old 10-26-2011, 03:08 AM
rummur s.c.'s Avatar
rummur s.c. rummur s.c. is offline
rummur s.c. is gaining momentum as a positive member of FTE.
Oh give me a break.. HAHA
lets just say the truck weighs between 8000 and 12000..
If you need a more exact number, you really should just drive her down to your local scale.. (I suggest you wait till they're closed if its a DOT scale) Sneak onto your local transfer station scale.. strap some garbage cans to the back. Thats how got the scale weight dropped on my 800 truck. It was a crane for its first 30 years then it got down sized to mechanic truck.. Much lighter.
Old 11-01-2011, 10:13 PM
CF LN7000 CF LN7000 is offline
CF LN7000 is starting off with a positive reputation.
I have a 1990 workready catolog and in 1990(dont see too much of a difference from 1987 to 1990) there were 3 F700's offered with that drivetrain combination. One had a 24,500 GVW, 153 WB and chassis weight was 9,170 lbs. Next was 28,000 GVW, 153in WB and chassis weight was 9,040 lbs. Last was was 28,000 GVW, 207in WB and chassis weight was 9,531 lbs. Hope this helps
2011 F250 actual weight Biggziff 1999 to 2016 Super Duty 19 06-17-2015 06:20 AM
2011 6.7 Diesel F250 4x4 SRW 3.55 Axles runch00 6.7L Power Stroke Diesel 33 03-19-2012 06:37 PM
Lift Kit madmatt14 1999 to 2016 Super Duty 7 09-17-2011 09:23 PM
Is this a proper explaination of trailer tow capicity for a truck? Chris89lx Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 18 03-27-2009 05:12 PM
Towing capacity F150 Ibby Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 7 05-03-2006 10:41 PM
Tags
1986, 2006, bed, f150, f700, ford, fordf700curbweight, height, large, lariat, problems, supercrew, trucks, weight, weightofanf700
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
