Charging system problem!! - Ford Truck Enthusiasts Forums
Old 10-24-2011, 08:17 PM
Sooner73415 Sooner73415 is offline
Sooner73415 is starting off with a positive reputation.
I have a 2003 f150 xlt flareside. I am having major charging system problems. Last night the charging system warning light came on. Today I replaced the alternator and had the battery checked. Both are good to go, but my battery is still draining and the light is still on. Fuses appear good. No idea what is going on, someone please help!!
Old 10-24-2011, 08:53 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
You need to make a test to see if the system is chargeing.
Place a voltmeter accross the battery and observe the voltage just after cranking and startup.
It should show 15 plus volts and taper back in just a few minutes as an indication the system is chargeing under regulator control.
There is a charge lead fuse on the firewall called a megafuse with 175 amp rateing.
There should be a second fuse in an inline holder near the alternator. It is a 20 amp.
Be sure the plugup at the alternator is set in tight and no blades are bent over.
A little about the charge lamp circuit.
It is powered through the ignition switch and a fuse.
If it lights it shows that circuit is complete and good.
It lights when it gets a ground from the alternator regulator.
When the alternator is outputting at a high enough level, the regulator take the ground away and the charge light goes out as an indication the alternator is outputting.
If it stays on, there is a system issue with the alternator.
Maybe you got a bad replacement.
Check it out first so you know what you have.
Replacing parts without final testing leaves you in confusion.
Good luck.
Old 10-24-2011, 09:00 PM
I've already done all this. Mine is a 2003, it does not have the inline fuse, nor the mega fuses on the firewall. My problem still exists. I'm not getting any voltage from the orange/blue wire coming out of the alternator harness.
Old 10-25-2011, 02:04 PM
Well ok for not having the fuses.
If you see an issue, change the alternator again.
You don't have many choices.
Battery light on, but alternator is charging??? saleen065 1999 to 2016 Super Duty 24 07-27-2015 09:31 AM
Battery Charge Warning Light Archuriel 1987 - 1996 F150 & Larger F-Series Trucks 5 10-01-2013 06:30 AM
Charging issue 2005 F350 6.0 Tim98TA Electrical Systems/Wiring 3 09-11-2013 07:29 AM
Check charging system Paul37 1997-2006 Expedition & Navigator 1 08-02-2011 12:06 PM
1980 F-150 Alternator Question Dorsai 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 04-10-2011 09:47 AM
Tags
1978, 1996, 2003, 2007, 250, charge, charging, check, diesel, f100, f150, ford, light, system, truck, warning, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
