Squealing belt driving me crazy!
Old 10-24-2011, 02:04 PM
Dufftrucks's Avatar
Dufftrucks
Dufftrucks is offline
1995 f250, 5.8 and driving me crazy! I replaced the belt and that worked for about 200 miles and now it's back. Sometimes you can hear it at idle, sometime not till about 1,000rpm. Sometimes {but not often}, you can't hear it at all and other times it's all you can hear. Sometimes it just abruptly stops squealing all together. I'm thinking it might be the auto belt tightener? Anyone with any input? Thanks.
Old 10-24-2011, 02:05 PM
ford1977owner's Avatar
ford1977owner
ford1977owner is offline
i think someone in a different forum on here mentioned a pulley being bad, but i dont remember but i know i saw a similar post somewhere else before
Old 10-24-2011, 02:33 PM
White Max's Avatar
White Max
White Max is offline
Check the idler and tensioner pulley bearings. One (or both) of them is likely to be the source of your squeal.
Old 10-25-2011, 04:14 AM
luconn3's Avatar
luconn3
luconn3 is offline
belt squeeking
I had the same issue on my 95 f150 5.8 about a year ago. Idler pulley was shot, belt tensioner pulley was shot, replaced both and still squeeked. When watching them as engine was running noticed that smog (air) pump pulley was intermitantly locking up and causing belt to slide across it and get hot and smoke a little. Replaced that and no problem since. Good luck.
Old 10-25-2011, 04:17 AM
86F150302's Avatar
86F150302
86F150302 is offline
Make sure all pulleys look / spinning fine
Make sure tensioner is working good.
Get a gatorback belt..
Old 10-25-2011, 06:40 AM
jroehl's Avatar
jroehl
jroehl is offline
Also, make sure all your pulleys are clean as well as rust- and moisture-free (no fluids leaking onto the belt or pulleys anywhere). DO NOT use belt dressing! Use NON-CHLORINATED Brake Parts cleaner, spraying everything down really well with it (may squeal in the process, but should clean off contaminants).
Jason
CoreLokt
03-14-2016 06:13 PM
twallace
01-06-2014 08:28 PM
bluemtn95ford
25
02-10-2013 11:30 PM
motox214
1983 - 2012 Ranger & B-Series
11-16-2005 10:53 AM
cmoore99
01-29-2005 09:45 PM
Quick Reply: Squealing belt driving me crazy!
