vacum pump testing???
You will know when you apply your brakes. If you keep steady pressure on them, they will work properly. If you pump them and the pedal gets extremely hard with NO stopping power, you can bet its your vacuum pump. You can also start the truck and pull the line off of the back of the pump, I don't know how much vacuum it should pull, but you'll know by putting your finger over the hose. It should grab your finger pretty good. Mine had very weak suction, I put a new pump on it, (about $125), worked like a charm.
That was on my 97' F350 PSD.
redlineps
03-15-2007 02:57 PM
charles jones
11-10-2006 07:45 PM
