SCT x3 and Edge CS Monitoring plus DPF Delete
Hey Guys,
Anyone using this set up: SCT x3 and Edge CS for monitoring. Ive talked to some people and this is the set up they recommend for the 6.4 TD. I am also interested in what to use for the DPF delete. I dont want to swap my exhaust out because im truly looking for MPG gain and not to much performance. Anyone using a stock exhaust with a DPF delete pipe?
Im running the AFE cat & dpfe delete pipe with the stock turbo pipe, muffler & tail pipe ... For now.
I'm hoping the MBRP muffler (that I'm about to install) will quiten down the air blowing noise, since it's twice as long as the short stock muffler ???
Do you think I should install the MBRP with the "CUPPED" scoops "Towards" the engine ??
I installed this same exact muffler on my 7.3L with the scoops turned AWAY from the engine & it is quiet & without this horrible air noise.
A/Ox4
17
07-12-2012 07:15 PM
BowDown
04-03-2006 12:05 AM
eeglot
03-21-2004 06:34 AM
