STUMP = Mystery Brakes
I have a 1956 Ford F350 Dually, I installed all new brake cylinders, wheels and master. Bled the system, and the brakes work fine. In the morning, they appear to have weakened, and the petal goes almost to the floor, and pumping the brakes does nothing. But after driving for 5-10 minutes, they get firmer and firmer, and if I drive longer, they get so hard that the brake lights stay on and the BACK wheels, not the front, start to lock up to the point the truck wont move. The brakes are pretty simple, pedal goes to master cylinder with a pressure sensor on the back,.... WHAT am I missing ???
Wally
1951 F1 - "Lucille"
Hi. Did you replace the flex hose that is between the end of the hard line and the block on the rear housing. Some times they will claps inside and the fluid will flow under pressure to the wheel cylinders but won't let it return so each time you step on the brakes the pressure will build until the brakes lock up. When the truck sits over night the fluid will gradually weep back to the master cylinder. If you haven't changed the two flex lines on the front and the one at the rear you should do so.
Hope this helps.
Hope this helps.
Njmyers
03-20-2016 11:28 AM
byron74f100
04-20-2010 02:25 PM
