89 f350 start problem
Old 10-24-2011, 08:08 AM
bigfoot7180's Avatar
bigfoot7180
bigfoot7180 is offline
a friend of mine has a 89 f350 with a 460 and it wont start when cranking it with the key.but if the key is on pull it 3 feet and its running what would cause this?
Old 10-24-2011, 01:28 PM
bigfoot7180
i guess we're all stumped lol
Old 10-24-2011, 02:38 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
A few possibilities.
Bad/low battery.
Loose/dirty battery wire terminals.
Loose battery to engine ground wire.
Burnt/corroded/bad battery wires.
Bad starter motor.
Old 10-24-2011, 02:56 PM
bigfoot7180
turns over fine just wont start.unless you pull or push it.
Old 10-24-2011, 03:20 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
Another possibility is a bad ignition switch (bolted to steering column under the dash).
ht99vpi
1978 - 1996 Big Bronco
04-27-2011 09:28 AM
74scamp
01-04-2010 09:50 PM
Rossta86
Electrical Systems/Wiring
10-18-2005 07:51 PM
oricle
03-12-2005 12:00 PM
Quick Reply: 89 f350 start problem
