T444E water pump - Page 4 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
T444E water pump
  #46
Old 12-07-2012, 01:32 AM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
No keep this one going, I like it myself.
Chet
  #47
Old 12-07-2012, 12:33 PM
Nicmike's Avatar
Nicmike Nicmike is offline
Proud Sheepdog
Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.
Update....
I am too dumb to have figured this out BEFORE I bought the two fittings from JEGS. The larger fitting (3/4 NPT to 1" hose barb) is only needed by the OBS guys. If you have a 99-03 truck, YOU DO NOT NEED TO BUY IT. I wasted $20 on that due to my lack of attention to detail.... Also, 4 ft of 5/8 heater hose will be more than enough to reroute the line from the top of the pump down to the bottom of the pump (and out of the way of the fuel bowl bolts!)
Good news is: That brings the price of the project down!!! Cost now is right at $210 for the newer powerstroke owners.
I am going to edit the previous lists with a note for that fitting. I have also decided to go with an ELC coolant so I don't have to mess with the SCA additives.
  #48
Old 12-07-2012, 03:44 PM
th67ss's Avatar
th67ss th67ss is offline
th67ss is gaining momentum as a positive member of FTE.
Thanks for making up the part list! I thought on the other thread he just used the existing heater hose?
I need to re-read this thread again.
  #49
Old 12-07-2012, 03:48 PM
Nicmike's Avatar
Proud Sheepdog
The existing heater hose is molded a certain way, and will not work by simply re-routing it. It would kink if you tried to use it on the new install. 4' of new hose is only like $6. I am in the process of painting the pump now and flushing the old coolant from the system. I also found that the old lower radiator hose cannot be cut and re-used on this project. The outlet on the new pump is too large in diameter for the old hose.
  #50
Old 12-07-2012, 11:21 PM
Nicmike's Avatar
Proud Sheepdog
Here are some photos of the removal of the shut off valve to replace the o-ring:
  #51
Old 12-07-2012, 11:24 PM
Nicmike's Avatar
Proud Sheepdog
Here is a photo of the inside of the cavity where the valve seats:
  #52
Old 12-07-2012, 11:28 PM
Nicmike's Avatar
Proud Sheepdog
Here is the reason the pump will only work with the short t-stat. It is very shallow. Also, a photo of the t-stat that is specifically made for this pump. Notice the gasket fits around the circumference of the t-stat and seals from both top and bottom....not just the top like the others.
  #53
Old 12-07-2012, 11:31 PM
Nicmike's Avatar
Proud Sheepdog
The pump got dinged up in two places on the face of the pump...probably during shipment from China to USA for assembly. Anyway, 15 seconds with a good file, and the dings were gone and smooth. These could have possibly caused the pump not to sit flush with the front cover if I had not noticed them. Inspect your pump well when you get it.
  #54
Old 12-07-2012, 11:34 PM
Nicmike's Avatar
Proud Sheepdog
Redneck paint prep....but it works really good!
  #55
Old 12-07-2012, 11:40 PM
Nicmike's Avatar
Proud Sheepdog
Here is a photo of the primer and the Ford blue result:
  #56
Old 12-07-2012, 11:47 PM
Nicmike's Avatar
Proud Sheepdog
I also drained and flushed the coolant system today while I was waiting for the paint to dry on the pump. I flushed it twice with tap water before I ran out of daylight. I then went in search of Heavy Duty ELC coolant. I did not find any at 4 different part stores. They all said they quit carrying it.
I settled for Prestone ELC with no silicates or phosphates. It isn't HD, but it should do. The only HD coolant I could find was with SCA precharge in it, and I decided I didn't want to mess with test strips and keeping up with the SCAs. Because I WILL forget....
I used the Prestone flush kit they sell at Wallyworld. It worked very well and was easy. The block plug on the passenger side was not too hard to get off, but much more difficult to get back on. The driver's side was a snap. Both plugs come out without much effort. The passenger side is just hard to get at with the starter on there. Point your ratchet handle toward the front of the engine while removing the passenger side plug! I was nice and wet when I was done. There is a nice write up on this site by member Gooch, so I won't beat that procedure to death. Besides, his write up is ten times better than I could do, and he is a "coolant expert"
I shall continue the job in the morning, and I will post more pictures. Please let me know if there are any specific photos you would like taken, and I will accomodate.
I couldn't have made it through today without my hired help. She really knows her stuff...
  #57
Old 12-07-2012, 11:52 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Please post the exact Prestone coolant you used. I have a bad feeling you do not have an OAT ELC, and will need to add SCA's.
Does it say it meets the CAT EC-1 specs?
Stewart
  #58
Old 12-07-2012, 11:56 PM
Stewart_H's Avatar
Using a universal swivel, once you get it placed in the plug the first time, it's really easy-peezy. Just make sure you go over the starter with the ratchet to access the plug.
Gooch is the man when it comes to coolant info.
His procedure has been posted on many diesel forums on the 'net because he is the authority when it comes to ELC.
Gooch's Coolant Flush Procedure and In-Depth Coolant Information - FTE
Stewart
  #59
Old 12-08-2012, 12:07 AM
Nicmike's Avatar
Proud Sheepdog
It does not say it meets EC-1. I could not find ANY anywhere that meets that standard. It is Prestone ELC concentrate...just not HD. It is silicate, phosphate, borate and nitrite free and meets ASTM D3306 & D4985 (whatever they are...).
If it absolutely won't work, I can put it in my car. It is due for a coolant flush, too.
  #60
Old 12-08-2012, 12:13 AM
aawlberninf350's Avatar
aawlberninf350 aawlberninf350 is online now
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
Sorry if I missed it, but did you post up the weight of the pump? Curious as to difference with Ford aluminum pump.
Coolant filters nateairman 1994.5 - 1997 7.3L Power Stroke Diesel 101 03-18-2016 11:08 PM
239 Y Block Water Pump fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-25-2016 12:21 AM
1971 351w water pump style Carmax 1967 - 1972 F-100 & Larger F-Series Trucks 2 11-25-2015 08:02 PM
1992 E-350 460 water pump replacement question Spaznaut 1968-2013 Full Size Vans 3 05-08-2015 07:44 AM
If you have the to choose ELC which is better?? carl2591 1999 - 2003 7.3L Power Stroke Diesel 6 12-06-2014 10:58 AM
Tags
99, belt, bushing, coolant, cps, diesel, f250, ford, installation, location, pipe, pump, t444e, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
