T444E water pump - Page 3 - Ford Truck Enthusiasts Forums
T444E water pump
  #31
Old 11-21-2012, 07:46 AM
honeydew honeydew is offline
honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.
Looking forward to seeing your pics and impressions Mike.
  #32
Old 11-21-2012, 09:58 AM
1fixitman's Avatar
1fixitman 1fixitman is offline
1fixitman has a very good reputation on FTE.1fixitman has a very good reputation on FTE.1fixitman has a very good reputation on FTE.1fixitman has a very good reputation on FTE.
I believe this is the link you guys or gals may be looking for. It is the IH upgrade write up. I hope it ok to post on our site as it goes thru another site and then comes back to our site for the PDF file.
http://www.google.com/url?sa=t&rct=j...Dg61XQ&cad=rja
and if you want the direct link on our site it is here.
http://www.ford-trucks.com/forums/attachment.php?attachmentid=62394&%3Bd=1349603865
Just type in IH Water pump upgrade in google and the fun begins.
I know it is petty and I am begging but my green dots above could use some love. I am at about 165 points and I do contribute a lot on this site.
Dwayne
  #33
Old 11-21-2012, 10:59 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Let the greenies worry about themselves, Dwane. They'll come, all in due time.
Patience, grasshopper......
Pop
  #34
Old 11-21-2012, 11:27 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Go hang out in GNAC and post your thoughts on politics or post jokes. You'll get a bunch.
Or post up that you're a female and you'll be maxed out within a couple months.
Stewart
  #35
Old 11-21-2012, 11:33 AM
Nicmike's Avatar
Nicmike Nicmike is offline
Proud Sheepdog
Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.
Stewart
LOL!! Now THAT is funny!!!
  #36
Old 11-21-2012, 11:39 AM
Stewart_H's Avatar
And true.
Stewart
  #37
Old 11-21-2012, 01:17 PM
Yup.
Greenies don't really mean much around here, insofar as technical abilities.
Pop
  #38
Old 12-03-2012, 02:20 PM
Nicmike's Avatar
Proud Sheepdog
Everything has arrived for the pump install. Now I need to wait for the weekend to do the job. All the parts came in at just under $250 total. I could have saved money by not getting the fittings from JEGS, but everything else was as cheap as I could find it. IH was the only place to get the 110 mm long bolts without waiting a week for shipping. There are three spots on the pump face where I will need to file down MINOR imperfections. The pump is assembled in USA...cast in China. It has a seriously heavy duty bearing in it, and is waaayyyyy heavier than the stock aluminum pump.THE LARGER BLUE FITTING IN THIS PHOTO IS NOT NEEDED UNLESS YOU HAVE AN OBS TRUCK
  #39
Old 12-03-2012, 04:08 PM
Nicmike's Avatar
Proud Sheepdog
Since the pump is cast iron, I am going to paint it Ford blue to keep rust off/out. I already have the paint, so no cost there. Just need to file down the boss right above the filter bypass valve. No letters/numbers cast near the pulley either, so no grinding there (as some have had to do).
  #40
Old 12-03-2012, 10:31 PM
bakerbuilttracks's Avatar
bakerbuilttracks bakerbuilttracks is offline
bakerbuilttracks is starting off with a positive reputation.
Quote:
Jealous even though i just replaced the wp on mine like 2 weeks ago ...... I will be doing this when the pump fails next go round. Any way you can post a parts list with part # to all the parts to do the job while you got everything on the table. That would be great and save a parts hunt for my self and others in the future. Congrats and again IM JEALOUS !
  #41
Old 12-04-2012, 08:05 AM
Looking forward to your install impressions Mike. Did you see the post somewhere about replacing the filter valve orings with viton?
  #42
Old 12-04-2012, 10:29 AM
Nicmike's Avatar
Proud Sheepdog
Yes, there is a pack of ten Viton o-rings in that photo next to the pump.
  #43
Old 12-04-2012, 08:40 PM
th67ss's Avatar
th67ss th67ss is offline
th67ss is gaining momentum as a positive member of FTE.
That would be great if you could give a parts list.
  #44
Old 12-05-2012, 12:30 AM
Nicmike's Avatar
Proud Sheepdog
Parts list has already been given in post #17, but I will do another that I modified from that one.
I am using all new bolts on my pump, however you MAY RE-USE your old bolts to save some money. These are low torque bolts, so your old ones are fine if you are on a tight budget. You will need to buy just a couple of bolts to go with your old ones - 2 x 60mm and 1 x 110mm if you re-use the old bolts.
You need to decide what type of coolant you will be using BEFORE you buy a filter to put on this pump (non-SCA vs SCA charged). Fleetguard WF2071 coolant filter w/4 SCA is an option/example that you would use with the green coolant. Thoroughly flush the system before doing this upgrade regardless of whether you are switching coolant type or not. You need to get everything out of the system (sand and other contaminants) to make this pump really go the distance for you.
Here is another version of the same list from post #17 with parts I did not need/use on my 2001 7.3L removed: (most of the credit for this list goes to FTE member TARM)
1831676C92 The Water Pump (I got this at Bus Parts Experts) $145 shipped
1817958C1 [x3] Bolt M8 x 1.25 x 30mm (Lowes-in stock) 3=$2
1817811C1 [x2] Bolt M8 x 1.25 x 60mm (Lowes-in stock) 2=$2
1818693C1 [x4] Bolt M8 x 1.25 x 110mm (International or NAPA has them in stock) 4=$11
Stant 205 #14252 (thermostat) I haven't bought mine yet...still deciding which to go with. *****YOU CANNOT USE A LONG STEM THERMOSTAT ON THIS PUMP ACCORDING TO OTHERS WHO HAVE DONE THIS***** In looking at my new pump, I am 100% sure this is correct. Other options for the short thermostat are Gates #33180/Car Quest#329-72/Napa #371-203 for the 203* thermo. O'Reilly's part number is 4252 for another option.
NAPA FM124 Flexihose Radiator Hose $52 and the Gates Green stripe flex hose #26517 - also $52 at O'Reilly's OUCH!!!
3/4 NPT to 1" male hose barb THIS PART IS ONLY NEEDED FOR AN OBS TRUCK( I bought 45 degree from JEGS) 1=$19.99 You can save a lot of money here and the one below by going local or using straight fittings...about $8-10 per fitting.
1/2 NPT to 5/8 male hose barb ( I bought 45 degree from JEGS) 1=$14.99
-205 Viton o-ring (I bought from the o-ring store dot com) 10=$5
Ford/New Holland water filter #CF4900 (you can get these filters in various brands anywhere with/without SCA charge e.g. NAPA 4070 for non-SCA or 4071 with SCA charge) 1=$11 with SCA or 1=$6 without SCA
6' of 5/8 heater hose (any auto-parts store) $9.
I could have done this for around $220 if I had been more patient with my parts buying and gotten non-45 degree hose fittings locally, a non-SCA filter from someone like Fleetfilter.com, and re-used my old bolts.
I think this is it. Let me know if I left anything out. I will find out this weekend if you guys don't notice anything obvious.
  #45
Old 12-06-2012, 08:11 PM
Nicmike's Avatar
Proud Sheepdog
5/8 Heater hose: 6 ft=$9 at AdvanceAuto
Also, IH makes a thermo for this cast iron pump. Heavy duty wrap-around gasket and made in USA. But, it is very pricey. $47!!!!
The party starts tomorrow. Will be taking lots of pics. You guys think I should start a new thread?
Coolant filters nateairman 1994.5 - 1997 7.3L Power Stroke Diesel 101 03-18-2016 10:08 PM
239 Y Block Water Pump fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-24-2016 11:21 PM
1971 351w water pump style Carmax 1967 - 1972 F-100 & Larger F-Series Trucks 2 11-25-2015 07:02 PM
1992 E-350 460 water pump replacement question Spaznaut 1968-2013 Full Size Vans 3 05-08-2015 06:44 AM
Water pump nbl346 1994.5 - 1997 7.3L Power Stroke Diesel 5 03-10-2013 09:06 PM
Tags
99, belt, bushing, coolant, cps, diesel, f250, ford, installation, location, pipe, pump, t444e, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
