T444E water pump - Page 10 - Ford Truck Enthusiasts Forums
T444E water pump
  #136
Old 08-23-2014, 12:06 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Originally Posted by clux View Post
..maybe more often.
I'm in Camp More Often.
Stewart
  #137
Old 08-23-2014, 01:00 AM
Nicmike's Avatar
Nicmike Nicmike is offline
Proud Sheepdog
Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.
Quote:
Originally Posted by aawlberninf350 View Post
Here ya go. We laptoppers can rotate the screen, please all you desktoppers don't hurt your neck. Anyway. That's the initial Baldwin that came with the Dieselsite bypass kit after 30k. Looks almost new. I'm running Ford Gold. I kept checking the temp of it expecting it to get cold as it plugged up and stopped flow, but it never did. New filter has approx 17k and I will wait for it to show evidence of plugging before I swap it out.
Thanks for posting up the pic. Anybody reading have thoughts about the bypass filter seemingly not picking much of anything up? I'm not knocking the bypass setups, but I would like to hear feedback from the more "experienced" minds that wander these halls and argue among each other
  #138
Old 08-23-2014, 07:26 AM
clux's Avatar
clux clux is offline
clux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputation
Quote:
I added a bypass at around 100,000 miles, at that point entirely on conventional silicate containing coolant. My first filter completely plugged in about 2000 miles to the point that it wasn't even warm after a half hour drive. Second filter made it about 6000. Since then (the last 10 years) I have changed them about every year to year and a half and haven't experienced another plugged filter. I don't have any concerns about the effectiveness of a bypass system removing solids.
  #139
Old 09-04-2014, 09:59 PM
carl2591's Avatar
carl2591 carl2591 is offline
carl2591 is gaining momentum as a positive member of FTE.
great article on water pump and coolant info.
I understand from past owner the water pump was replaced at 75K. Truck now has 168K so wondering what is normal life of these pumps. Not sure type of replacement pump it look like the OEM style with main bottom coming off right lower side of pump.
It does not appears to be leaking at this point.
It appears to have the gold coolant installed. So will most likely go back with that when changing out pump.. Was thinking about the cast iron IH pump and changing out O rings in pump as shown with better type rings.
What is recommend coolant the motorcraft or something else.
is this correct stuff
Amazon.com: Genuine Ford Fluid VC-7-B Gold Concentrated Antifreeze/Coolant - 1 Gallon: Automotive Amazon.com: Genuine Ford Fluid VC-7-B Gold Concentrated Antifreeze/Coolant - 1 Gallon: Automotive
how many gallons needed to do a good flush and replace. Was just going to drain coolant and refill with regular water from city tap run till hot with heater on and drain fluid, fill and flush again, then do pump replace and new coolant.
  #140
Old 09-05-2014, 01:27 AM
Stewart_H's Avatar
Quote:
If you have the Motorcraft Gold coolant already, I'd assume your 7.3 is a L99 or newer, yes?
If yes, I'd suggest a heavy duty ELC coolant meeting Cat EC-1 spec, like Chevron Delo HD ELC.
Gooch's Coolant Flush Procedure and In-Depth Coolant Information
Stewart
  #141
Old 09-05-2014, 02:57 PM
carl2591's Avatar
Stewart
thanks for the link to flush procedure.. I was reading about Delco and see it a better produce vs the ford gold one color fits all theme they have going.
good info from good people.
PS truck is 2003 sept build date.
  #142
Old 02-16-2015, 02:54 PM
AllaboutMPG's Avatar
AllaboutMPG AllaboutMPG is offline
AllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to behold
Yes I know it's an old thread but a good one with excellent info. I've added the International water pump to my list of upcoming to do's but want to ask those who have done it if the 1/2 npt to 5/8 hose barb has to be 45 degrees to fit or will a straight do the job just fine. I saw a complete kit on line and it appeared to have the straight fitting. Anyone done this with the straight???
Thanks, Paul
  #143
Old 02-23-2015, 09:20 PM
Nicmike's Avatar
Proud Sheepdog
Straight fitting will certainly work. I used the 45 to give the hose coming off it a kink-free angle to where it needed to go up above.
  #144
Old 02-23-2015, 10:15 PM
Thanks Mike,
I was looking at pics online before my water pump actually arrived and trying to gather parts. Some seem to have only one boss for a fitting at the outlet end but others have 2 like yours. The single boss units looked like it was on top and a straight would be better. I have both a straight and 45 fitting and will see which fits best once I get the old pump off and can hold the new in place. Sure looks like the 45 will be the right one though.
I really appreciate the time you put in on this thread. It really made it an easy decision to go ahead and do it. I was going to do a seperate bypass system when I found this write up. I like this much better.
  #145
Old 02-23-2015, 10:34 PM
ProjectDually's Avatar
ProjectDually ProjectDually is offline
ProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to beholdProjectDually is a splendid one to behold
I never installed my bypass kit. This seemed like the cleaner way to go, and looks more like a factory install. I'll probably end up selling the kit to somebody who wants to go that route.
  #146
Old 08-10-2015, 12:42 PM
carl2591's Avatar
o-rings for filter shut off on t444e water pump
get my HONKING new OEM made in US International Harvester water pump and was wondering if anyone has the replacement o-rings for the filter shut off i could buy..
I could not find them on diesel o ring site so not sure the cost..
let me know how much for one and i will send you cash or do paypal.
thanks
carl
that is one big heavy mother for sure.
  #147
Old 08-10-2015, 04:24 PM
JT250's Avatar
JT250 JT250 is offline
JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.
thanks
carl
I just put mine on a week ago . I did not get the oring or I would send you one. The hardest part is getting the fan/shroud off and on again by yourself. Otherwise just takes time. I went ahead and painted it since it was cast iron. It is definitely a beast compared to the other one.
  #148
Old 08-11-2015, 11:51 PM
Nicmike's Avatar
Proud Sheepdog
Quote:
-205 Viton o-ring (I bought from the o-ring store dot com) 10=$5
From earlier in the thread in case you missed it
  #149
Old 08-23-2015, 11:45 AM
carl2591's Avatar
-205 Viton o-ring (I bought from the o-ring store dot com) v75203 part number.
min order is 4 and shipping is $5.95..
What happen to put them in an envelope put a .44 or whatever it cost now to mail, put a name on it and send it .. hell i don't mind paying a dollar for the supplies. I might get 15 or so and sell them to guys on the forum for cost of o'ring $.26, stamp $.47, envelope $.20, profit ?, total cost of $1.50
what the problem with the o'ring that come in them again.??
10=$5
  #150
Old 08-24-2015, 06:34 PM
Nicmike's Avatar
Proud Sheepdog
the Viton material is much more durable than the o-ring that comes with it. Someone who pioneered this thing stated their o-ring failed soon after install, and everyone has been replacing them on install now. If you feel lucky, don't bother replacing yours.
I don't think I have any left. Mailed them all out to members to do their own installs...
Coolant filters nateairman 1994.5 - 1997 7.3L Power Stroke Diesel 101 03-18-2016 10:08 PM
239 Y Block Water Pump fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-24-2016 11:21 PM
1971 351w water pump style Carmax 1967 - 1972 F-100 & Larger F-Series Trucks 2 11-25-2015 07:02 PM
1992 E-350 460 water pump replacement question Spaznaut 1968-2013 Full Size Vans 3 05-08-2015 06:44 AM
Water pump nbl346 1994.5 - 1997 7.3L Power Stroke Diesel 5 03-10-2013 09:06 PM
Tags
99, belt, bushing, coolant, cps, diesel, f250, ford, installation, location, pipe, pump, t444e, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
