Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-23-2011, 08:19 PM
plsix plsix is offline
Garage is empty, add now
plsix is starting off with a positive reputation.
need your expertise for swap
I recently picked up a 59 f100 thats been converted to 4x4.
It has a 292, a t98 tranny and dana 24 transfer case to i believe a 9in rear.
can i put in a 400 with c6 which came out of a f350 and keep my transfer case with out any problems. and have the shifter on the steering column.
My concern is the drive line from the c6 to the dana 24.
Thanks for looking.
  #2 (permalink)
Old 10-28-2011, 09:36 AM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
You may have a length problem with the C6 if it has the long tailhousing. With the T98, which is a pretty short transmission, there is a short propeller shaft, to the best of my memory about 20" long, to the transfer case if the truck has the transfer case in the OEM location.
Not knowing how you are going to mount the engine and C6, you might be able to get away with a shorter propeller shaft made up of two yokes and about a 2" minimum length of shaft or as long as needed.
You are going to have to do some measuring to see if it will fit.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
